Solved Can no longer access signatures.
Any help will be appreciated.
Bill
I should have also said that presently the existing signatures are showing twice with each post.
Bill
I have downloaded the newest version of Blue Eagle5.
Unfortunately, now the signatures and the text of the posts are displayed over each other.
Thanks for your help.
Bill
- dirk.potyka
The signature is not below the texts as usual but higher positioned so that it appears overlayed by the texts of the posts.
E.g.; www.rcboot.de/index.php/forum/uservorste...euer-in-bayern#35813
(Posts from "Chaos")
This started when updating to 1.5.0 (not sure if it was already with RC3 but I do not think so)
backend - kunena - template manager - edit less - custom.less -
div.kmsgbody .kmsgsignature {
position: relative !important;
click on save, and look if its ok now.
My friend Anita solved the issue. You can see the discussion here:
www.kzrider.com/kunena/8-about-the-site/...dual-profiles#788486
Thank you
Bill
- dirk.potyka
that was fast
Problem is fixed. Thanks again !
Cheers
-Dirk
