Kunena 6.2.6 released
Question Smart search produce wrong url - error 404 component was´t found
5 years 10 months ago - 5 years 9 months ago #1 by 4max
Smart search on my site produce this url:
vse-o-krmivech.cz/ component/kunena/krmeni-psu/5-obezita/7
which produce 404 error - page not found (component wasn´t found)
Correct url is:
vse-o-krmivech.cz/ forum/krmeni-psu/5-obezita/7
Kunena Report config:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 32M
Joomla default template details : iReview3 | author: ClickFWD LLC | version: 3.7.2 | creationdate: June 2018
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.0.14 | creationdate: 2018-03-14
Kunena template params:
Kunena version detailed: Kunena 5.0.14 | 2018-03-14 [ Stephen Hawking ]
Plugins: Search - Kunena Search 5.0.4
Modules: Kunena Latest 5.0.4
Last edit: 5 years 9 months ago by 4max.
5 years 9 months ago - 5 years 9 months ago #2 by 4max
Additional informations:
So, forum funcions correctly, however, all smart search results that point to forum post results with the same error.
It seems that for unknown reason the /forum/ in the url is replaced with /component/kunena/
In the smart search the forum post are indexed like this:
index.php?option=com_kunena&view=topic&catid=5&id=11&mesid=48
What could be wrong? Please help.
I would like to add that I have deleted all Kunena menus and purged deleted menus. Than rebuild new menues in Kunena component.
See attachment.
I have also tried to set Direct Component Access in the Kunena SEO Setting to YES. The results: All found posts links to the beginning of the topic (first page).
I Also tried to use Joomla simple Search. See issues connected with it here:
www.kunena.org/forum/general-questions-a...tay-at-the-same-page
I am desperate. I am trying very hard but I am not able to solve the problem.
I am wondering why there is not answer to my question. Do I ask stupid question, is there some obvious solution that I do not see that is not worth to answer. If yes pls just give me a hint. Thanks.
5 years 9 months ago #3 by rich
I also find no solution that works but I've entered this problem in the bug list.
The following user(s) said Thank You: 4max
Time to create page: 0.438 seconds
