Solved Where are font awesome icons?
5 years 10 months ago #1 by yodam
I'm using Protostar and I've signaled this bug on the 5.1.0, but on 5.1.1 I've the same problem.
I don't see the search icon on recent discussion (and other pages):
<i aria-hidden="true" class="fas fa-search"></i> on Firefox debugger
Can I do something about? is "fas" correct or is "fa"? I've tryed to use "fa fa-search" but situation is not improving
Thanks!
5 years 10 months ago #2 by 810
Replied by 810 on topic Where are font awesome icons?
You need to enable"Load External CDN Fontawesome" option on the kunena template options.
3 years 4 months ago #3 by AdWeb
Replied by AdWeb on topic Where are font awesome icons?
810 wrote: You need to enable"Load External CDN Fontawesome" option on the kunena template options.
Hi i have same problem in Protostar, Joomla and Kunena latest version, enable CDN not resolve problem
I have CSS style menulink with fas and fa-icontype, problem with FAS howto fix that?
fontawesome i load using @import in css file
3 years 4 months ago #4 by xillibit
@AdWeb: can-you paste here please your Kunena report configuration ?
3 years 4 months ago #5 by AdWeb
if u need link to site mycity.joomla.com/forum
3 years 4 months ago #6 by rich
Replied by rich on topic Where are font awesome icons?
yodam wrote: I don't see the search icon on recent discussion (and other pages):
AdWeb wrote: Hi i have same problem in Protostar, Joomla and Kunena latest version, enable CDN not resolve problem
I'm sorry, but I can't see the same problem.
3 years 4 months ago #7 by xillibit
Which css class do-you have set for each menu item ?
3 years 4 months ago #8 by AdWeb
for example
menulink fas fa-bullhorn
3 years 4 months ago #9 by AdWeb
module menu not work correct with forum page
3 years 4 months ago #10 by rich
== Topic moved (it's a general website question) ==
It's not the same problem as by the topic author. Please create at the next time your own topic.
The information of the stylesheet must be in the index of your Joomla template.
Example:
<link rel="stylesheet" https://use.fontawesome.com/releases/v5.15.1/css/all.csss">
Afterwards, if you enter to the menu item only fa fa-bullhorn the symbol should be displayed.
Time to create page: 0.723 seconds
