Solved DOM Error: Found 2 elements with non-unique id
6 years 3 months ago - 6 years 3 months ago #1
by Cyrusxxxx
DOM Error: Found 2 elements with non-unique id was created by Cyrusxxxx
Hello to all, after upgrading Google Chrome to version 63.0.3239.84 I have started recieving following errors related to login form of Kunena (ver 5.0.12):
This error is visible here also when I am not logged in.
Should I just ignore this?
Thank you!
[DOM] Found 2 elements with non-unique id #login-passwd: (More info: https://goo.gl/9p2vKq)
<input id="login-passwd" type="password" name="password" class="form-control" tabindex="2" size="18" placeholder="Lozinka" required> <input id="login-passwd" type="password" name="password" class="form-control" tabindex="2" size="18" placeholder="Lozinka" required>
kategorije:1
[DOM] Found 2 elements with non-unique id #login-remember: (More info: https://goo.gl/9p2vKq)
<input id="login-remember" type="checkbox" name="remember" value="yes">
kategorije:1
[DOM] Found 2 elements with non-unique id #login-username: (More info: https://goo.gl/9p2vKq)
<input id="login-username" type="text" name="username" class="form-control" tabindex="1" size="18" placeholder="Korisničko ime"> <input id="login-username" type="text" name="username" class="form-control" tabindex="1" size="18" placeholder="Korisničko ime">
Thank you!
Last edit: 6 years 3 months ago by Cyrusxxxx. Reason: Added one more screenshot
6 years 2 months ago #2
by gurubob
Replied by gurubob on topic DOM Error: Found 2 elements with non-unique id
Google sent me here ...
Looks like Chrome is now complaining about elements in the DOM with the same ID. In the case of this site there's a responsive login for non-dekstop sites that is the username and password.
This is going to be a widespread problem for many web developers and not specific to just this site or to Joomla.
Cheers,
- Bob -
Cheers,
- Bob -
6 years 2 months ago #3
by 810
Replied by 810 on topic DOM Error: Found 2 elements with non-unique id
We have 2 menu's . one for normal screen and one for the mobile. So we need to create a different name for the mobile one, and copy all the custom javascript.
basically more lines of codes for the same functions, i don't why google want this behavior.
6 years 2 months ago - 6 years 2 months ago #4
by gurubob
Duplicate ID's on a page have been a no-no for a long time. Don't use a duplicate ID to target it via JS, you could just use a custom attribute, e.g. data-id ...
$('*[data-id="login"]').on('click', function() { ... });
Last edit: 6 years 2 months ago by gurubob.
6 years 2 months ago #5
by 810
ok, fixed the issue, will be on the next K5.1 release.
The following user(s) said Thank You: Cyrusxxxx
6 years 2 months ago #6
by Cyrusxxxx
Replied by Cyrusxxxx on topic DOM Error: Found 2 elements with non-unique id
Thank you 810.
Time to create page: 0.370 seconds
