Kunena 6.2.6 released
Question I don´t see BBCode Toolbar
www.f1losdominguitos.com/index.php/foro
I have read this problem occours many times after upgrading for an older version of Kunena. Actually my version is 5.0.11, but it was updated from kunena 1.7.2 last week. The way I followed to update was the next one: 1.7.2 -> 2.0.4 -> 3.0 -> 3.0.6 -> 4.0 -> 5.0.11. Joomla was also updated from 2.5.13 to 3.8 following this way: 2.5.11 -> 2.5.28 -> 3.5.1 -> 3.8.0
Anyway, I don´t think the problem is caused by a bad update, because I have another site (a test site) which was installed from scracth using joomla 3.7.5 and Kunena 5.0.11, and I have the same problem. This is my test site:
www.f1ld.x10host.com/index.php/forum
Both sites have the same template, Could the problem be in the CSS styles?
Thanks in advance.
latest version of Jommla 3.8
and latest version of kunura orums...
the editor toolbar on the front end disappears as i mouse over it, i can see it at first, but the tool bar disappears and turns into like a blank screen window..
HELP
this also is the case for JCE Editor as well as tinyce editor or whatever the default joomla is
thanks
Mark
you should have got all icons collection (png files) in this folder or similar:
/components/com_kunena/template/(your_template_name)/assets/images
If your icons are missing you can copy them from crypsis template. They should be here.
/components/com_kunena/template/crypsis/assets/images
If icons are still not showing in the toolbar maybe css classes are missing. Check your kunena css file (located in /components/com_kunena/template/(your_template_name/assets/css or similar). There should be one class for button. For instance, this is the class for Bold button:
#kunena.layout .markItUp .boldbutton a{
background-image: url(/components/com_kunena/template/(your_template_name)/assets/images/bold.png)
If again they are missing you can add one class for each button or copy all of them from crypsis template. Edit crypsis' kunena css file and copy all .markItUp classes.
Hope it helps you
myale wrote: i have the same problem with my site
HELP
thanks
Mark
Sorry, I´ve read right now that your icons dissapears only when mouse is over them. In this case check in kunena.css the hover class of the element which dissapears. let me know what is your page and maybe I could help you better.
Regards.
- TwizyForum
- Junior Member
I switched to Blue_Eagle5 and the button bar is missing (also in hover).
Changing back to Crypsis does not fox it.
PNGs ar at their place an the path is ok.
They just do not render!
Had something similar before, but it disappeared when I edited the BBCode setting in the template (removed twitter, soundcloud)
That seemed to trigger something.
But could only be coincidental since it does not work now.
Yes, cache is empty
- TwizyForum
- Junior Member
I get 404 error messages like these.
....media/kunena/cache/blue_eagle5/css/assets/images/icons/arrow.png
The files don´t show in this cache folder.
In "components/com_kunena/template/blue_eagle5/assets/images/icons/arrow.png" everything is fine.
I even can Acces them trough the browser.
How can I refresh the cache so that the template will find these files?
Only when i mouse over it i see the Alt texts like 'Underline' 'Align center' etc...
Any help ?
