Kunena 6.2.6 released
Question How to increase fonts size in Kunena v5 [SOLVED]
Fonts that I want to increase:
- All subforum titles and their descriptions.
- All topic titles inside each subforum.
- Fonts when we see a forum topic.
- Fonts when we type our message to write a forum post.
Can someone redirect me for a location to all those .css files so that I can edit them?
If each Kunena template has different .css files, just give me examples for the default Kunena template and I will find my way.
Iam a newbie in coding so please be specific.
Thank you.
The problem is that I downloaded a Template and it has very tiny comment box. Only two lines.
Thank you.
Which file do I need to edit and where is the location of it?
I want the full path directory of that file. Of custom.css . If you tell me the path in the default template then I will find it in the template that I use.
or in your Joomla template "templates/template name/css/custom.css"
