Solved Bad quality of avatar
7 years 9 hours ago - 7 years 9 hours ago #1
by tomsson
Bad quality of avatar was created by tomsson
Last edit: 7 years 9 hours ago by tomsson.
7 years 3 hours ago #2
by rich
Replied by rich on topic Bad quality of avatar
You use the Community Builder? Please see here:
www.kunena.org/forum/general-questions-a...lurred-profile-image
- djangothebest
6 years 11 months ago #3
by djangothebest
Replied by djangothebest on topic Bad quality of avatar
I have exactly the same issue.
But still not able to fix the problem. Even with the linked topic.
Can anyone help me please.
THX
THX
6 years 11 months ago #4
by rich
If you have changed the thumbnail size, you must upload the avatar again.But still not able to fix the problem. Even with the linked topic.
- djangothebest
6 years 11 months ago #5
by djangothebest
I did, but the quallity in a forums topic is still bad
- djangothebest
6 years 11 months ago #6
by djangothebest
Solved.
I changed the settings in the CB Configuration-Avatar several times and now I found a setting which works for me.
I set the standard max size for the picture to 300 and the standard max size for the preview picture to 150.
If I change the preview picture size back to the default value of 86x60 I have again the problem with the bad quality.
So, as I said, the above setting works for me.
Thx for your support.
Time to create page: 0.499 seconds
