- Thank you received: 2
Question Modal forms are not accessible in Editor
- eSilverStrike
- Topic Author
- Junior Member
When creating a new topic or replying, if you click on the emoticons icon or link icon on the toolbar the modal form comes up but is disabled and darken like the rest of the page. Nothing is clickable on the page
You can see an example of this by adding a test forum post here .
Does anyone have an idea on how to fix this?
- eSilverStrike
- Topic Author
- Junior Member
Please disable both optimizer and test, whether this code works. Add this code in your custom.less. docs.kunena.org/en/manual/backend/templates/edit-less Then empty the cache.
- eSilverStrike
- Topic Author
- Junior Member
I have disabled the optimizer so you can look into it further.
Try this code in your Joomla template custom.css, but it's only a workaround until you have a better solution. Then check in your webpage whether in other sites is all correctly displayed.
- eSilverStrike
- Topic Author
- Junior Member
- eSilverStrike
- Topic Author
- Junior Member
Have you tested the kunena theme with Bootstrap 3.3.7?
I also tested what I could of some of the possible solutions from here with no result. Does any stand out for you that may be the solution:
stackoverflow.com/questions/10636667/boo...ing-under-background
- eSilverStrike
- Topic Author
- Junior Member
I have left this fix in for now until a better solution becomes available.
Have you tested the Crypsisb3 template with bootstrap 3.3.7? Does the same issue I am having happen or is something else going on?
I've not tested yet. But the problem exists not only with Kunena, also with others extensions users have problems (see your posted link).Have you tested the Crypsisb3 template with bootstrap 3.3.7?
Why don't you use the suggestion from the iReview-Template-Forum? forum.jreviews.com/topic/29212-bug-irevi...g-issues-with-modal/I have left this fix in for now until a better solution becomes available.
