- Thank you received: 2
Kunena 6.3.8 Released
The Kunena team has announce the arrival of Kunena 6.3.8 [K 6.3.8] in stable which is now available for download as a native Joomla extension for J! 4.4.x/5.0.x/5.1.x/5.2.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 and issues discovered during the last development stages of K 6.3
Note: Please go to the Kunena Dashboard after an upgrade so that the Kunena database tables are also updated.
If you simply want to know if something is possible, use the General Questions and How-tos category.
Notes:
- The material in this category is not verified by the Kunena Project team for usability with any version of Kunena. People who use information here do so at their own risk. The project team takes NO responsibility for maintaining or supporting anything in this category.
- If you are not offering money to pay for your custom needs, please use the category Custom work - not offering to pay (registered users only).
- Topics not resolved in 3 months will be closed and locked
Question Migrate joomla 4
Does it help if i got the Superuser acces ?
This is not possible. As I had already written, the necessary rights are missing. Even a superadmin doesn't have them if he can only access the website.Sorry as I am, you will have to wait until your friend is well enough to do it for you. You have until the beginning of August 2023, after which support for Joomla 3.x ends.Does it help if i got the Superuser acces ?
I have no idea what you did. But this limitation has nothing to do with Kunena and can also only be fixed by your friend/provider.What now ?
I followed the giud and checked that there were no extetions that could make trouble,. if there were any, I uninstalled them and simply clicked on the update link (Joomla) that automatically came and then what you can see happened.
www.joomla-tips.org/joomla-troubleshoote...n-size-problems.html
From this
To this
Can the field with the smileys be made bigger? It is a bit difficult to see which smileys they actually are
And is there an option to change the background colors etc.
Thanks (And sorry for my earlier acid reflux, I was just getting frustrated)
But I just want to know if it is possible to change the width so that there will be a little "air" in the sides.
There is no general solution for this. This requires custom CSS adjustments, depending on the Joomla template used.And is there an option to change the background colors etc.
