Kunena 6.4.8 Released
Solved problem with buttons after update
After update to the newest version I got a problem with buttons, they don't look ok. In the middle of button is a white space. I reinstalled kunena, but it didn't work.
my site is: http://xn--jzyk-polski-rrb.pl/forum/
You need a demo user to see that
login: tati
pswrd: tati
What can I do to repair that?
you need to add this few lines to your Joomla template CSS file
this must work, I don't see that code loaded on your site, so be sure to insert it in the right file and be sure to clean all cache from your site (Joomla and Joomla Template)
I need your help with one more thing.
When user wants create new topic all layout (joomla and kunena) crashes.
It happened only in that one situation.
When I replay, quick replay or want to do anything else it works ok.
Have you any advice?
when I click on New Topic button all works well. When this happen? After click on "save" button?
How can I reproduce that?
Thank You for Great Support!
