- Thank you received: 1434
Solved Last posts not showing in index view
11 years 4 months ago #11
by 810
Replied by 810 on topic Last posts not showing in index view
Kunena 2.0.3 is out now, please install the new version. And try again. It should fixed the issue.
regards 810
regards 810
The following user(s) said Thank You: chessfarrell
- chessfarrell
- Topic Author
11 years 4 months ago - 11 years 4 months ago #12
by chessfarrell
Replied by chessfarrell on topic Last posts not showing in index view
Thanks for the info. I've just updated Kunena and it seems they applied the fix mentioned earlier, which doesn't solve all the problems (even though it's already better than it used to be). I'll show you:
(1. Index view: category showing a 9-month old post)
(2. Category view)
(3. No topics and replies)
It seems the index view (#1) should display the post in green (#2), not the one in red. So the issue seems to endure, which attachment #3 seems to confirm: another category that was affected by the bug displays no topic and no reply while it's full of them.
If anyone experiencing the same problem can reproduce it with a new category so that we can inform the developers, don't hesitate to post the instructions here.
(2. Category view)
Last edit: 11 years 4 months ago by chessfarrell. Reason: spelling
11 years 4 months ago #13
by 810
ok,
- go to backend
- Kunena
- Tools
- Recount Statistics
- Select all option then click on Recount Statistics on the top right
- then Synchronize Users
- select all options then click on sync
- go to backend
- Kunena
- Tools
- chessfarrell
- Topic Author
11 years 4 months ago #14
by chessfarrell
Sorry, I don't know why I didn't think of checking the tools. :dry:
I did everything (stats and users) and it solved the main issue: all the dates are now showing how they should be showing (at least for now).
But the no topic and reply issue endures:
(1. No reply and no topic)
Kunena counts them correctly (cf. green rectangles) but doesn't display them correctly in index view (cf. red rectangles). To be fair, it's a new/different issue, so maybe I should open a new thread.
11 years 4 months ago #15
by 810
thnx for the bug report. I added it to git.
github.com/Kunena/Kunena-2.0/issues/1212
We will investigate the issue.
11 years 4 months ago #16
by thefly
Replied by thefly on topic Last posts not showing in index view
ok ... I downloaded the upgrade and now, following all your instructions, seems to work correctly ... index page has the right post in a prominent place. Unfortunately we are experencing problems with the IT language pack but I think that could be just a cache issue or something related to operative system.
Thx for your help.
Thx for your help.
Time to create page: 0.699 seconds
