- Thank you received: 3
Kunena 6.2.6 released
Solved K 2.0.2, K 2.0.3: problems with preview
- roland_d_alsace
- Topic Author
- Junior Member
After upgrade from k2.0.1 to k2.0.2 the preview option before submit a post dont display nothing (preview field leave blank).
Have you an idéa ?
Regards.
- Thank you received: 35
- roland_d_alsace
- Topic Author
- Junior Member
With firebug :
JSON.parse: unexpected character
Line 503
After upgrade from 2.0.1 to 2.0.2 The Prewiew button does not work for all users. How I can fix it? Im using Kunena 2.0.2
Are-you using default template for Kunena and Joomla! ?
Can-you give me your site url with a test account ?
- roland_d_alsace
- Topic Author
- Junior Member
my.pneuboat.com/forum/23-informations/41...version-3/reply.html
Merci de supprimer ces infos, c'est un site en production / it's the production site !
Amicalement / Regards.
PS: je pensai que le problème aurait pu venir du code d'un smiley perso, mais ce n'est pas le cas, j'ai desactivé le smiley et le problème demeure...
I asked me if the problem is not with my own smiley code, but no...
Par contre j'ai aussi trouvé un problème dans le fichier de langue francaise, une chaine avec quote non echapé utilisé qui genera une erreur js :
document.write('Chargement de l'éditeur de BBCode ...')
/ Otherwise, i found problème with language key used in javascript (the quotes in french translation is not stripslashed) here is : document.write('Chargement de l'éditeur de BBCode ...')
- roland_d_alsace
- Topic Author
- Junior Member
I have downgrade from 2.0.2 to 2.0.1 and the preview is OK ??
(And i don't have any js error in firebug script console)
...but after a new upgrade to 2.0.2 always the same problem : when i click on preview button : preview field stay blank and i have js error :
Line 503.
