- Thank you received: 1
Question KD 2.0.3 plugin does not work
I have set the "Default Forum Category" to the corresponding Kunena category ID and I set the "Allowed Content Categories" to the corresponding Joomla Content Category. See screenshot.
I can't figure out how to show the article with the discussion following, with a link to the actual forum post.
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
I have set the ID for "Category Mapping" to the Joomla category ID and "Default Forum Category" to the Kunena forum category ID. I am smh here trying to figure this out...? I received the following when I activated debugging:
[KunenaDiscuss debug: Constructor called in com_content ]
[KunenaDiscuss debug: onPrepareContent.Deny: Category 15 was disabled in the category map. ]
[KunenaDiscuss debug: onPrepareContent: we are in article/ page. ]
[KunenaDiscuss debug: onPrepareContent: Article 19 ]
[KunenaDiscuss debug: onPrepareContent: Searched for {kunena_discuss:#}: Custom Topic not found. ]
****EDIT****
I added the content ID to "Allowed" and everything works.
Thanks!
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
jpc0480 wrote: I still couldn't get this to work?
****EDIT****
I added the content ID to "Allowed" and everything works.Thanks!
I installed the new K2.0.3 updates, including the new Discuss Plugin, and the Discuss plugin is still not working for me.
There is a long post of this issue in the forum but that thread was closed since it was reported that the K2.0.3 Discuss Plugin was fixed:
www.kunena.org/forum/K-2-0-Kunena-Discus...icle?start=10#135567
Can you tell me what you did for the workaround? I'm not clear on what you mean by setting the content ID to "Allowed" and everything then worked with the plugin.
Note to forum moderator: If I posted in the wrong section/thread then let me know and I will move my post to the section of the forum you recommend.
Thanks for any advice!
810 wrote: hi, you must enter a number on "Allowed content id" 0 = every content
Hi 810,
I checked my K Discuss plugin settings and I do have the Allowed Content ID at 0.
So should I post the bug/problem with K Discuss 2.0.3 not being fixed yet? The other forum thread was closed since the forum mod wrote the bug was fixed for 2.0.3 before the release of the update.
I'm not sure where to post so the Discuss plugin devs are aware of the issue.
I hope this helps.
Hi 810,
Please make a screenshot from your settings and post it here.
I added the values to Category Mapping. The 15 is my Joomla Category ID and the 24 is my Kunena Forum Category. I then added the Kunena values to the Default Forum Category and the my Joomla values for the Allowed Content Categories.
Hope this helps.
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
If your settings are not working, set Show Debug Information = Yes and let us know what messages appear on your article(s).
See Kunena Discuss "quick and dirty" instructions for use for more information.
