Question Migrate Avatars from Fireboard to Kunena ?
10 years 11 months ago #1 by intel1
I successfully migrated fireboard to kunena.
BUT users avatars are not showing in New kunena. Plz suggest what to do. Plz reply soon.
Regards,
10 years 11 months ago #2 by intel1
Admin, Plz reply soon.
10 years 11 months ago #3 by 810
please add kunena report.
10 years 11 months ago #4 by intel1
Which report you needed ?
Am not getting any error. Its just avatar pics are not appearing.
Am using Kunena 2.0.4. I migrated database from fireboard 1.0.4 stable.
I installed new Joomla 2.5. Then migrated old db to new db.
Everything is ok except Avatar pics. I think Kunena is using separate folder for avatar than Fireboard folder.
PLZ PLZ reply soon.
Regards,
10 years 11 months ago #5 by sozzled
intel1 wrote: Which report you needed?
It would help if you looked at the FAQs page to find out what we mean by the configuration report. :)
10 years 11 months ago #6 by intel1
htaccess: Missing | PHP environment: Max execution time: 5000 seconds | Max execution memory: -1 | Max file upload: 130M
Joomla default template details : beez_20 | author: Angie Radtke | version: 2.5.0 | creationdate: 25 November 2009
Plugins: None
10 years 11 months ago #7 by intel1
Waiting for your valuable reply. Plz reply soon.
Regards,
10 years 11 months ago #8 by xillibit
From which fireboard version did-you have migrated ?
In your actual Kunena installation, in the directory /media/kunena/avatars/ do you find the avatars from fireboard ?
10 years 11 months ago #9 by intel1
I migrate from Fireboard 1.0.4
Kunena created all avatar folders, But i didn't find Avatar from Fireboard. If you can tell me any manual process to correct it, I can do.
Please reply soon.
Regards,
10 years 11 months ago #10 by intel1
Please reply soon.........
Time to create page: 0.379 seconds
