Kunena 6.4.8 Released
Merged K 1.7 -> K 2.0.3 upgrade and now forum contents are "gone"
i need this version too - desperately! would you send me kunena 2.0.2 to c.krug[at]cowic.de?
Had to restore my site 2 times as the forum was damaged and i have to migrate it to another server ...
thanks so much!
There is no "Kunena 7.3.2."
Did you look at Last post date "42 years ago" - access denied to topic - database errors ?
ktbgreat3 wrote: Could you give me alittle more info? Not sure what to do?
with a FTP client select component >> com_kunena and administrator >> component >> com_kunena and set permision to 755.
I have the same problem after upgrading to 2.0.3 on a 2.5 site that was migrated earlier with jupgrade.
- Webguy101au
I upgrade and all topics and replies have been removed? Not checked users.
I read perhaps try 2.0.2, so I rolled back, some menu options were a bit screwy, but I can live with that.
So I then try 2.0.2, I even crossed my toes this time, same thing, no errors at all, but all topics and replies seem to have been removed?
Is there a fix for this at all?
Is all the material still really there, and it is just the counts screwed up? Hmmm, maybe I should check that.
Cheers
Counts screwed up? Have you tried recount category statistics in the backend?
- Webguy101au
I have upgraded joomla 1.5 pack to 2.5 alone with Kunena forum. I have got all the categories after up gradation but not able to get the posts from the category.
Please let me know if any one get like this problem.
Thanks in advance
Regards
Snehal
