Kunena 6.2.1 Released with module latest 6.0.4 and module kunena stats 6.0.4
The Kunena team has announce the arrival of Kunena 6.2.1 [K 6.2.1] which is now available for download as a native Joomla extension for J! 4.3.x/4.4.x/5.0.x. This version addresses most of the issues that were discovered in K 6.1.0 and issues discovered during the last development stages of K 6.1
Question loops indéfinitely
10 years 3 months ago #1 by joel
loops indéfinitely was created by joel
Hello, When I click on one of my forums, the computer loops endlessy (v2.04)
www.informatique-bureautique.com/forum/index
thanks for your answer
My configuration :
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : sunshine | author: Fio | version: 1.0.5 | creationdate: 26.10.08
Third-party SEF components: sh404sef 1.0.19_Beta
Plugins: Content - Kunena Discuss 2.0.4 | JomSocial - My Kunena Forum Posts 2.0.4
Modules: Kunena Login 2.0.4
10 years 3 months ago #2 by xillibit
Replied by xillibit on topic loops indéfinitely
You are using a Kunena version and Joomla! version which is in end of life, so i advise you to upgrade to lastest versions.
10 years 3 months ago - 10 years 3 months ago #3 by sozzled
Replied by sozzled on topic loops indéfinitely
There are some important observations that need to be made about this issue:
1) The problem has been discussed many times before in this forum. The problem is caused by having two menu items that conflict with one another. These issues are discussed in "This webpage has a redirect loop" and the solution can be found in that topic. If you do not want to read the whole topic, it is summarised simply in the Wiki article Kunena Menu issues
2) Joomla never supported "legacy mode". Kunena is not tested on J! 1.5.x systems running with the Joomla - Legacy plugin enabled. You need to disable this plugin. Unless and until you remove legacy mode from your J! 1.5 site, this problem will never be resolved.
You should read Legacy mode in the Wiki to find out how to disable "legacy mode".
3) sh404SEF 1.0.19 beta is several years out of date (and unsupported by anythng-digital.com ) As far as we know, sh404SEF has not been compatible with Kunena for a very long time. See
  1. anything-digital.com/forum/extension/sh4...ible.html?p=1#p48743 ; and
  2. www.kunena.org/docs/Kunena_Features#Inte...er_Joomla_extensions
Last edit: 10 years 3 months ago by sozzled.
Time to create page: 0.326 seconds
