configuration report
Merged
Gantry 4 and problems with Kunena profile editing
I see the problem, armaden1. The problem is that you are using a different, third-party Kunena template - one that was not designed or maintained by the Kunena project - that was not the one you told us about in the configuration report that you posted before. I'd you are having problems with a third-party template, please contact the developer of that template for further assistance.
Should you require further help from this community, please use the K. 2.0 Blue Eagle template.
I use stadard Kunena template (K. 2.0 Blue Eagle) , when i wrtie post in this forum. I think problem is solved. I must remove RokBox 2 (
www.rockettheme.com/extensions-joomla/rokbox
), and now i see this tabel. Unfortunately I have another problem. When i change avatar i have error:
Last edit: 10 years 11 months ago by sozzled. Reason: Changed subject to improve relevance for search purposes
I have seen something like this "open_basedir restriction in effect" message before. The last time that I saw
a topic on this issue
, the recommended suggestion was to check folder and file permissions. See Securing Kunena
. I hope this helps.
