configuration report
Question Attachments not uploading
11 years 5 months ago - 11 years 5 months ago #11
by pequeno74
Replied by pequeno74 on topic Attachments not uploading
I understand you perfectly. It is a particular problem. I apologize for my insistence. I do not want you to feel overwhelmed by me. I try to express myself and understand the best I can in English, but sometimes I fail.
With Database schema tool I have this results:
Schema difference
Database Schema
and with Diagnostic Tool
How to solve the database schema difference?
Schema difference
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE schema>
<schema type="diff">
<table name="kunena_announcement" action="alter">
<field name="title" type="tinytext" null="0" action="alter" after="id"/>
</table>
<table name="kunena_categories" action="alter">
<field name="class_sfx" type="varchar(20)" null="0" action="alter" after="headerdesc"/>
</table>
<table name="kunena_users" action="alter">
<field name="birthdate" type="date" null="0" default="0001-01-01" action="alter" after="gender"/>
</table>
</schema>
Database Schema
<!DOCTYPE schema>
<schema>
<table name="kunena_aliases">
<field primary_key="yes" name="alias" type="varchar(255)" null="0"/>
<field name="type" type="varchar(10)" null="0"/>
<field name="item" type="varchar(32)" null="0"/>
<field name="state" type="tinyint(4)" null="0" default="0"/>
<key name="alias" unique="1" columns="alias"/>
<key name="state" columns="state"/>
<key name="item" columns="item"/>
<key name="type" columns="type"/>
</table>
<table name="kunena_announcement">
<field primary_key="yes" name="id" type="int(3)" null="0" extra="auto_increment"/>
<field name="title" type="tinytext" null="1"/>
<field name="created_by" type="int(11)" null="0" default="0"/>
<field name="sdescription" type="text" null="0"/>
<field name="description" type="text" null="0"/>
<field name="created" type="datetime" null="0" default="0000-00-00 00:00:00"/>
<field name="published" type="tinyint(1)" null="0" default="0"/>
<field name="ordering" type="tinyint(4)" null="0" default="0"/>
<field name="showdate" type="tinyint(1)" null="0" default="1"/>
<key name="PRIMARY" unique="1" columns="id"/>
</table>
<table name="kunena_attachments">
<field primary_key="yes" name="id" type="int(11)" null="0" extra="auto_increment"/>
<field name="mesid" type="int(11)" null="0" default="0"/>
<field name="userid" type="int(11)" null="0" default="0"/>
<field name="hash" type="char(32)" null="1"/>
<field name="size" type="int(11)" null="1"/>
<field name="folder" type="varchar(255)" null="0"/>
<field name="filetype" type="varchar(20)" null="0"/>
<field name="filename" type="varchar(255)" null="0"/>
<key name="mesid" columns="mesid"/>
<key name="userid" columns="userid"/>
<key name="hash" columns="hash"/>
<key name="filename" columns="filename"/>
</table>
<table name="kunena_categories">
<field name="parent_id" type="int(11)" null="1" default="0"/>
<field name="name" type="tinytext" null="1"/>
<field name="alias" type="varchar(255)" null="0"/>
<field name="icon_id" type="tinyint(4)" null="0" default="0"/>
<field name="locked" type="tinyint(4)" null="0" default="0"/>
<field name="accesstype" type="varchar(20)" null="0" default="joomla.level"/>
<field name="access" type="int(11)" null="0" default="0"/>
<field name="pub_access" type="int(11)" null="0" default="1"/>
<field name="pub_recurse" type="tinyint(4)" null="1" default="1"/>
<field name="admin_access" type="int(11)" null="0" default="0"/>
<field name="admin_recurse" type="tinyint(4)" null="1" default="1"/>
<field name="ordering" type="smallint(6)" null="0" default="0"/>
<field name="published" type="tinyint(4)" null="0" default="0"/>
<field name="channels" type="text" null="1"/>
<field name="checked_out" type="tinyint(4)" null="0" default="0"/>
<field name="checked_out_time" type="datetime" null="0" default="0000-00-00 00:00:00"/>
<field name="review" type="tinyint(4)" null="0" default="0"/>
<field name="allow_anonymous" type="tinyint(4)" null="0" default="0"/>
<field name="post_anonymous" type="tinyint(4)" null="0" default="0"/>
<field name="hits" type="int(11)" null="0" default="0"/>
<field name="headerdesc" type="text" null="0"/>
<field name="class_sfx" type="varchar(20)" null="0" default=""/>
<field name="allow_polls" type="tinyint(4)" null="0" default="0"/>
<field name="topic_ordering" type="varchar(16)" null="0" default="lastpost"/>
<field name="numTopics" type="mediumint(8)" null="0" default="0"/>
<field name="numPosts" type="mediumint(8)" null="0" default="0"/>
<field name="last_topic_id" type="int(11)" null="0" default="0"/>
<field name="last_post_id" type="int(11)" null="0" default="0"/>
<field name="last_post_time" type="int(11)" null="0" default="0"/>
<field name="params" type="text" null="0"/>
<key name="published_pubaccess_id" columns="published,pub_access,id"/>
<key name="category_access" columns="accesstype,access"/>
<key name="parent_id" columns="parent_id"/>
</table>
<table name="kunena_configuration">
<field primary_key="yes" name="id" type="int(11)" null="0" default="0"/>
<field name="params" type="text" null="1"/>
</table>
<table name="kunena_keywords">
<field name="name" type="varchar(40)" null="0"/>
<field name="public_count" type="int(11)" null="0"/>
<field name="total_count" type="int(11)" null="0"/>
<key name="name" unique="1" columns="name"/>
<key name="public_count" columns="public_count"/>
<key name="total_count" columns="total_count"/>
</table>
<table name="kunena_keywords_map">
<field primary_key="yes" name="keyword_id" type="int(11)" null="0"/>
<field primary_key="yes" name="user_id" type="int(11)" null="0"/>
<field primary_key="yes" name="topic_id" type="int(11)" null="0"/>
<key name="keyword_user_topic" unique="1" columns="keyword_id,user_id,topic_id"/>
<key name="user_id" columns="user_id"/>
<key name="topic_user" columns="topic_id,user_id"/>
</table>
<table name="kunena_messages">
<field name="parent" type="int(11)" null="1" default="0"/>
<field name="thread" type="int(11)" null="1" default="0"/>
<field name="catid" type="int(11)" null="0" default="0"/>
<field name="email" type="tinytext" null="1"/>
<field name="subject" type="tinytext" null="1"/>
<field name="time" type="int(11)" null="0" default="0"/>
<field name="ip" type="varchar(128)" null="1"/>
<field name="topic_emoticon" type="int(11)" null="0" default="0"/>
<field name="hold" type="tinyint(4)" null="0" default="0"/>
<field name="ordering" type="int(11)" null="1" default="0"/>
<field name="hits" type="int(11)" null="1" default="0"/>
<field name="moved" type="tinyint(4)" null="1" default="0"/>
<field name="modified_by" type="int(7)" null="1"/>
<field name="modified_time" type="int(11)" null="1"/>
<field name="modified_reason" type="tinytext" null="1"/>
<key name="thread" columns="thread"/>
<key name="ip" columns="ip"/>
<key name="time" columns="time"/>
<key name="locked" columns="locked"/>
<key name="hold_time" columns="hold,time"/>
<key name="parent_hits" columns="parent,hits"/>
<key name="catid_parent" columns="catid,parent"/>
</table>
<table name="kunena_messages_text">
<field primary_key="yes" name="mesid" type="int(11)" null="0" default="0"/>
<field name="message" type="text" null="0"/>
<key name="PRIMARY" unique="1" columns="mesid"/>
</table>
<table name="kunena_polls">
<field name="title" type="varchar(100)" null="0"/>
<field name="threadid" type="int(11)" null="0"/>
<field name="polltimetolive" type="datetime" null="1"/>
<key name="threadid" columns="threadid"/>
</table>
<table name="kunena_polls_options">
<field name="pollid" type="int(11)" null="1"/>
<field name="text" type="varchar(100)" null="1"/>
<field name="votes" type="int(11)" null="1"/>
<key name="pollid" columns="pollid"/>
</table>
<table name="kunena_polls_users">
<field name="userid" type="int(11)" null="1"/>
<field name="lasttime" type="timestamp" null="0" default="0000-00-00 00:00:00"/>
<field name="lastvote" type="int(11)" null="1"/>
<key name="pollid" unique="1" columns="pollid,userid"/>
</table>
<table name="kunena_ranks">
<field primary_key="yes" name="rank_id" type="mediumint(8) unsigned" null="0" extra="auto_increment"/>
<field name="rank_title" type="varchar(255)" null="0" default=""/>
<field name="rank_min" type="mediumint(8) unsigned" null="0" default="0"/>
<field name="rank_special" type="tinyint(1) unsigned" null="0" default="0"/>
<field name="rank_image" type="varchar(255)" null="0" default=""/>
<key name="PRIMARY" unique="1" columns="rank_id"/>
</table>
<table name="kunena_sessions">
<field primary_key="yes" name="userid" type="int(11)" null="0" default="0"/>
<field name="allowed" type="text" null="1"/>
<field name="lasttime" type="int(11)" null="0" default="0"/>
<field name="readtopics" type="text" null="1"/>
<field name="currvisit" type="int(11)" null="0" default="0"/>
<key name="PRIMARY" unique="1" columns="userid"/>
<key name="currvisit" columns="currvisit"/>
</table>
<table name="kunena_smileys">
<field primary_key="yes" name="id" type="int(4)" null="0" extra="auto_increment"/>
<field name="code" type="varchar(12)" null="0" default=""/>
<field name="location" type="varchar(50)" null="0" default=""/>
<field name="greylocation" type="varchar(60)" null="0" default=""/>
<field name="emoticonbar" type="tinyint(4)" null="0" default="0"/>
</table>
<table name="kunena_thankyou">
<field primary_key="yes" name="postid" type="int(11)" null="0"/>
<field primary_key="yes" name="userid" type="int(11)" null="0"/>
<field name="targetuserid" type="int(11)" null="0"/>
<field name="time" type="datetime" null="0"/>
<key name="postid" unique="1" columns="postid,userid"/>
<key name="targetuserid" columns="targetuserid"/>
</table>
<table name="kunena_topics">
<field name="category_id" type="int(11)" null="0" default="0"/>
<field name="icon_id" type="int(11)" null="0" default="0"/>
<field name="ordering" type="int(11)" null="0" default="0"/>
<field name="posts" type="int(11)" null="0" default="0"/>
<field name="attachments" type="int(11)" null="0" default="0"/>
<field name="poll_id" type="int(11)" null="0" default="0"/>
<field name="moved_id" type="int(11)" null="0" default="0"/>
<field name="first_post_id" type="int(11)" null="0" default="0"/>
<field name="first_post_time" type="int(11)" null="0" default="0"/>
<field name="first_post_userid" type="int(11)" null="0" default="0"/>
<field name="first_post_message" type="text" null="1"/>
<field name="first_post_guest_name" type="tinytext" null="1"/>
<field name="last_post_userid" type="int(11)" null="0" default="0"/>
<field name="last_post_message" type="text" null="1"/>
<field name="last_post_guest_name" type="tinytext" null="1"/>
<key name="category_id" columns="category_id"/>
<key name="hold" columns="hold"/>
<key name="posts" columns="posts"/>
<key name="hits" columns="hits"/>
<key name="first_post_userid" columns="first_post_userid"/>
<key name="last_post_userid" columns="last_post_userid"/>
<key name="first_post_time" columns="first_post_time"/>
<key name="last_post_time" columns="last_post_time"/>
</table>
<table name="kunena_user_categories">
<field primary_key="yes" name="category_id" type="int(11)" null="0"/>
<field name="role" type="tinyint(4)" null="0" default="0"/>
<field name="allreadtime" type="datetime" null="1"/>
<field name="subscribed" type="tinyint(4)" null="0" default="0"/>
<key name="PRIMARY" unique="1" columns="user_id,category_id"/>
<key name="category_subscribed" columns="category_id,subscribed"/>
<key name="role" columns="role"/>
</table>
<table name="kunena_user_read">
<field name="category_id" type="int(11)" null="0"/>
<field name="message_id" type="int(11)" null="0"/>
<field name="time" type="int(11)" null="0"/>
<key name="user_topic_id" unique="1" columns="user_id,topic_id"/>
<key name="category_user_id" columns="category_id,user_id"/>
</table>
<table name="kunena_user_topics">
<field primary_key="yes" name="user_id" type="int(11)" null="0" default="0"/>
<field primary_key="yes" name="topic_id" type="int(11)" null="0" default="0"/>
<field name="posts" type="mediumint(8)" null="0" default="0"/>
<field name="owner" type="tinyint(4)" null="0" default="0"/>
<field name="favorite" type="tinyint(4)" null="0" default="0"/>
<key name="topic_id" columns="topic_id"/>
<key name="owner" columns="owner"/>
<key name="favorite" columns="favorite"/>
<key name="subscribed" columns="subscribed"/>
</table>
<table name="kunena_users">
<field name="view" type="varchar(8)" null="0" default="flat"/>
<field name="signature" type="text" null="1"/>
<field name="moderator" type="int(11)" null="1" default="0"/>
<field name="banned" type="datetime" null="1"/>
<field name="posts" type="int(11)" null="1" default="0"/>
<field name="avatar" type="varchar(255)" null="1"/>
<field name="karma" type="int(11)" null="1" default="0"/>
<field name="karma_time" type="int(11)" null="1" default="0"/>
<field name="group_id" type="int(4)" null="1" default="1"/>
<field name="uhits" type="int(11)" null="1" default="0"/>
<field name="personalText" type="tinytext" null="1"/>
<field name="gender" type="tinyint(4)" null="0" default="0"/>
<field name="birthdate" type="date" null="0" default="0000-00-00"/>
<field name="location" type="varchar(50)" null="1"/>
<field name="icq" type="varchar(50)" null="1"/>
<field name="aim" type="varchar(50)" null="1"/>
<field name="yim" type="varchar(50)" null="1"/>
<field name="msn" type="varchar(50)" null="1"/>
<field name="skype" type="varchar(50)" null="1"/>
<field name="twitter" type="varchar(50)" null="1"/>
<field name="facebook" type="varchar(50)" null="1"/>
<field name="hideEmail" type="tinyint(1)" null="0" default="1"/>
<field name="showOnline" type="tinyint(1)" null="0" default="1"/>
<field name="thankyou" type="int(11)" null="1" default="0"/>
<field name="rank" type="tinyint(4)" null="0" default="0"/>
<field name="gtalk" type="varchar(50)" null="1"/>
<field name="myspace" type="varchar(50)" null="1"/>
<field name="linkedin" type="varchar(50)" null="1"/>
<field name="delicious" type="varchar(50)" null="1"/>
<field name="friendfeed" type="varchar(50)" null="1"/>
<field name="digg" type="varchar(50)" null="1"/>
<field name="blogspot" type="varchar(50)" null="1"/>
<field name="flickr" type="varchar(50)" null="1"/>
<field name="bebo" type="varchar(50)" null="1"/>
<field name="websitename" type="varchar(50)" null="1"/>
<field name="websiteurl" type="varchar(50)" null="1"/>
<key name="group_id" columns="group_id"/>
<key name="uhits" columns="uhits"/>
<key name="banned" columns="banned"/>
<key name="moderator" columns="moderator"/>
</table>
<table name="kunena_users_banned">
<field name="blocked" type="tinyint(4)" null="0" default="0"/>
<field name="expiration" type="datetime" null="1"/>
<field name="created_by" type="int(11)" null="0"/>
<field name="created_time" type="datetime" null="0"/>
<field name="reason_private" type="text" null="1"/>
<field name="reason_public" type="text" null="1"/>
<field name="modified_by" type="int(11)" null="1"/>
<field name="modified_time" type="datetime" null="1"/>
<field name="comments" type="text" null="1"/>
<key name="expiration" columns="expiration"/>
<key name="created_time" columns="created_time"/>
</table>
<table name="kunena_version">
<field name="version" type="varchar(20)" null="0"/>
<field name="versiondate" type="date" null="0"/>
<field name="installdate" type="date" null="0"/>
<field name="build" type="varchar(20)" null="0"/>
<field name="versionname" type="varchar(40)" null="1"/>
<field name="state" type="text" null="0"/>
</table>
</schema>
messagetextsMissingMessage 2
messagesMissingBody 5
topicsInSection 0
topicsMissingCategory 0
messagesInWrongCategory 9
messagesOrphaned 8
pollsOrphaned 0
pollOptionsOrphaned 0
pollUsersOrphaned 0
Last edit: 11 years 5 months ago by pequeno74.
11 years 5 months ago #12
by pequeno74
I changed the db differences and the problem persists. Where I can find professional help?
11 years 5 months ago #13
by pequeno74
Replied by pequeno74 on topic SOLVED - Attachments not uploading
OK, I am stupid
The problem was in the Kunena configuration
Kunena Config > Front > Attached Limit= 0 :blush: :blush: :blush: :blush:
Time to create page: 0.473 seconds
