Kunena 6.3.2 released
The Kunena team has announce the arrival of Kunena 6.3.2 [K 6.3.2] in stable which is now available for download as a native Joomla extension for J! 4.4.x/5.0.x/5.1.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 and issues discovered during the last development stages of K 6.3
Note: Please go to the Kunena Dashboard after an upgrade so that the Kunena database tables are also updated.
Merged Before you post your question, read this first
11 years 11 months ago #41 by alsthom
I was facing excactly the same problem. But I solved it after many tests on a test site.
What I did;
- I changed the template and I used a joomla default one.
- I Cleared cache
- I enabled SEF! (strange huh?)
But after that, preview & add buttons are fine!
The following user(s) said Thank You: scientificman
11 years 11 months ago #42 by alsthom
I made another test today.
I had my old joomla installation in a folder (1.5.26) with kunena 1.7.2.
I did the upgrade to 2.0.1.
Succesfull upgrade...
Test buttons preview, add etc >>>dead!
Changed the kunena template from default to blue eagle 2.0
Test buttons> add is ok >preview is not!
Went to global configuration and enabled sef.
Test buttons >all ok!!!!
I hope this helps
11 years 11 months ago - 11 years 11 months ago #43 by sozzled
*** Topics merged ***
Please see msg #1 in this topic for the guide to solving these kinds of issues.
Last edit: 11 years 11 months ago by sozzled.
11 years 11 months ago #44 by Matias
Interesting find @alsthom - I was finally able to reproduce the issue.
Reported bug from preview issue:
github.com/Kunena/Kunena-2.0/issues/968
I cannot reproduce issues with other buttons in here or in my test sites. Buttons are fully working for me..
11 years 11 months ago #45 by scientificman
alsthom wrote: ...
I hope this helps
Thank you alsthom! It looks like my problem also. When I enabled SEF, I got test button working!
Unfortunately I don't need SEF feature on my site at this time. May be later...
Matias, if you need help to resolve this issue, I ready to allow administration privilegies for you.
11 years 11 months ago #46 by Matias
I can reproduce the issue locally, so I don't need access. There will probably be a new release in a few weeks as I would like to get most of the known issues fixed as soon as possible.
Kunena is mainly designed to work SEF turned on, but it should work without SEF as well.
11 years 11 months ago #47 by tracer
same issue. Preview does not work. www.officepanorama.com
Regards,
Thomas
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 250M
Joomla default template details : it_thesoftware | author: IceTheme | version: 1.6.0 | creationdate: 01 April 2011
Kunena default template details : Office Panorama 2.0 | author: Kunena Team / Werbemix | version: 2.0.0 | creationdate: 2012-07-02
Plugins: Content - Kunena Discuss 2.0.0
Modules: Kunena Latest 2.0.0 | Kunena Stats 2.0.0 | Kunena Login 2.0.0 | Kunena Search 2.0.0
11 years 11 months ago #48 by sozzled
tracer: You are using some kind of Javascript aggregator aren't you. Perhaps something like JCH Optimizer or ? (For people who use J! 1.5, they may be using code aggregator plugins like CssJsCompress , jFinalizer , ZT Speed Up Plugin or fwSiteOptimizer , too)
Many of these performance-enhancing products that aggregate (i.e. combine, minify and obfuscate) Javascript and/or CSS may sound great in theory but if you use them you need to remember that as soon as you start fiddling around with the standard of behaviour of Joomla's Javacript library (i.e. Mootools) you may affect the behaviour of other Joomla extensions (e.g. Kunena) that rely on it.
The main purpose of this topic is to advise people who have various Javascript-related problems (see msg #1 of this topic for the list) that Kunena needs Joomla's Mootools Javascript library to be allowed to function properly. As soon as people start fiddling with Mootools (by adding other Joomla extensions) that's when they may start to have problems.
In this particular case, because I cannot see the individual Javascript libraries that may have been installed on the site, I have no immediate clue as to the possible answer. I would therefore suggest that you remove whatever code aggregation plugin you are using and try Kunena without it.
11 years 11 months ago #49 by gochargers
I'm using the forum on my website but for some reason it wont let me attach a file, the buttons broken. How can I fix this?
11 years 11 months ago #50 by alsthom
sozzled wrote: Many of these performance-enhancing products that aggregate (i.e. combine, minify and obfuscate) Javascript and/or CSS may sound great in theory but if you use them you need to remember that as soon as you start fiddling around with the standard of behaviour of Joomla's Javacript library (i.e. Mootools) you may affect the behaviour of other Joomla extensions (e.g. Kunena) that rely on it.
@sozzled you mean that it is better to turn off theese futures? My template has an option to use or not use theese. You suggest to turn them off? Sorry but my english are poor....
Time to create page: 0.649 seconds
