- Thank you received: 1
Merged Hide / Disable login
Oh, right. Or that :blush:sozzled wrote: Did you read the topic Hide / Disable login ?
It's really easy and you do not need to know PHP.
A lot of these simple questions can be found by searching the forum topics.
Ok, thank you, the problem is solved.sozzled wrote: Did you read the topic Hide / Disable login ?
Need to remove the login block in kunena forum. Instead, login can be made on joomla login module.
-Dan Greenavis
