Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Merged Hide / Disable login
13 years 7 months ago - 13 years 7 months ago #130373 by Dom2012
Replied by Dom2012 on topic Hide / Disable login
Hi Jiminimonka,
Thanks for your reply.
Yeah, I saw that and I played around with the options but what I found was that the categories would vanish but the login area would not (though it would be disabled). I'm clearly missing something.
Anyway, here's my configuration set-up should it help to solve this.
Thanks,
Dom
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : rt_tachyon_j16 | author: RocketTheme, LLC | version: 1.6.5 | creationdate: December 12, 2011
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Third-party components: Jomsocial 2.6.2
Plugins: Content - Kunena Discuss 2.0.1
Modules: Kunena Latest 2.0.1
Last edit: 13 years 7 months ago by Dom2012.
13 years 7 months ago #130374 by Jiminimonka
Replied by Jiminimonka on topic Hide / Disable login
Try this:
Kunena Plugins » Kunena - JomSocial Integration » Plug-in: [Edit] » Parameters » Plug-in Parameters » Enable JomSocial Login = No
The login panel should then vanish from the top of Kunena.
Please read the FAQ.
Only one question per topic.
13 years 7 months ago #130408 by Dom2012
Thanks, that removed the login fields although I'm still seeing the user avatar and "Welcome/Last Visit/Private Messages" part of the grey box. I had hoped to remove the grey box altogether.
Can this be done?
Thanks,
Dom
13 years 7 months ago #130410 by sozzled
Replied by sozzled on topic Hide / Disable login
Where is this issue occurring - I cannot see it.
Your Joomla menu is confusing. I suggest you simplify things. Watch the video in The Kunena Menu to see how to re-create a standard Kunena menu. I hope that helps.
13 years 7 months ago #130572 by Dom2012
Thanks for getting back to me.
There seemed to be some sort of problem with the Kunena menu after I renamed it in the main menu. As a result, I lost the usual Kunena menu links (Index, Recent Topics, etc.).
I tried to fix this by following the instructions in the video you mentioned, but they vanished again.
I discovered that it was possible to retrieve them if I saved the forum in the main menu as an external link. Odd, but it worked.
The Kunena menu items are now back.
I was also able to change the width of the Joomla template using the mjindustry's instructions in the following link: www.rockettheme.com/forum/index.php?f=39...ic&start=165#p805750
I'm also including his instructions below for easier use:-
I have just tested this step by step and it works for me on rt_tachyon_j16
Download the attached zip file. Unzip it and then upload the file - mywidth.php - to your features directory in the template. For most people this will be via ftp to /public_html/your.domain/templates/rt_tachyon_j16/features
Now open the /templates/rt_tachyon_j16/template-options.xml file and look for the code at line 117....
<fieldset name="features" label="FEATURES"> <field name="viewswitcher-priority" type="hidden" default="1"/> <field name="logo-priority" type="hidden" default="2"/> <field name="copyright-priority" type="hidden" default="3"/> <field name="styledeclaration-priority" type="hidden" default="4"/>
...and insert this code...
<field name="dyngrid" default="60" type="text" class="text-short" label="mywidth"/>
...so the file should now look like this...
<fieldset name="features" label="FEATURES"> <field name="dyngrid" default="60" type="text" class="text-short" label="mywidth"/> <field name="viewswitcher-priority" type="hidden" default="1"/> <field name="logo-priority" type="hidden" default="2"/> <field name="copyright-priority" type="hidden" default="3"/> <field name="styledeclaration-priority" type="hidden" default="4"/>
Please note that the default is set to 60px, which is the same setting as the current template. Upload the amended file to replace the original.
Now go to Joomla admin and select the rt_tachyon_j16 template and go to template admin. In the features tab you should now have an option called mywidth and it should be displaying the 60 width.
Just change the width to suit your needs and then apply. Remember that there are 12 columns so if you set the column width to 100 then you will deliver a screen width of 1200px.
Hope this helps
It worked exactly as described for me. I found that 64px did the trick. You can see the result here: www.steinerparents.com/forum/index
I have attached the required file, mywidth.zip.
Thanks,
Dom
13 years 6 months ago #131359 by sultra
Hello
How do I remove the login menu on Kunena 2.0, so that appear on forum pages instantly just in category forum
thank you
Time to create page: 0.341 seconds
