configuration report
Merged K 2.0: How to make and edit announcements
11 years 1 month ago #21
by chesto
Replied by chesto on topic Creating an announcement
Exactly : new is not clicable
sorry i'm french & newbie
i miss the solution anywhere ?
11 years 1 month ago #22
Replied by sozzled on topic K 2.0: How to make and edit announcements
If "new" is not clickable, it's probably a Javascript library conflict. See msg #1 of
Before you post your question, read this first
11 years 1 month ago #23
by Jeymar
Replied by Jeymar on topic Activating annoucements
I've tried to activate the announcement box to no avail. I am superadministrator in Jommla 2.5.7 and administrator in Kunena 2.0.4. But the announcement link stays greyed out. I use the Aphotic 2.0 version II template. I tried with the blue template, but nothing changed. I still connaot write an annoucement. Can anyone help ?
Thanks.
Thanks.
11 years 1 month ago #24
*** Topics merged ***
The information in this topic should answer your questions, Jeymar
10 years 11 months ago #25
by NivenR
Replied by NivenR on topic K 2.0: How to make and edit announcements
Hi guys, I have gone through all on this topic, but still seem to be having issues. 'New' when clicking on Announcements seems to be unclickable. I have enabled announcements on Forum config/Front end, but still no luck. I am using version Joomla! 2.5.9 and Kunena 2.0.4. Could anyone please advise, thank you.
10 years 11 months ago #26
G'day, NivenR, and welcome to Kunena.
The reason that the "Add New" link may be unclickable for you(and not for others who have not reported this problem) probably has more to do with your Joomla environment than anything else.
Several common causes of this problem you are having are listed in msg #1 of Before you post your question, read this first . It is my guess that you have a Jaascript-related problem caused by another Joomla extension you have installed. Your configuration report may help us to know something about your Joomla environment.
Time to create page: 0.442 seconds
