Kunena 6.2.6 released
Solved How clean user cache
- kurisutofue
- Topic Author
10 years 10 months ago - 10 years 10 months ago #1
by kurisutofue
How clean user cache was created by kurisutofue
Hi guys,
How clean user cache from Kunena?
I still cannot find this option from "Synchronize users".
Is it anywhere else?
I need to update display in front of changes of user status (moderator or not) made from backend and I saw only user cache cleaning will give this effect.
Thanks!
Thanks!
Last edit: 10 years 10 months ago by sozzled. Reason: Remove reference to non-existent version of Kunena
The topic has been locked.
10 years 10 months ago #2
by xillibit
Replied by xillibit on topic How clean user cache
Start by upgrading to Joomla! 2.5.11, then if you go in tools, you will find Synchronize users function
- kurisutofue
- Topic Author
10 years 10 months ago #3
by kurisutofue
Replied by kurisutofue on topic How clean user cache
Thank you for your reply.
Actually, before to upgrade, I already have "Synchronize users" function.
But I don't have "Clean user cache" option.
I just have the other ones.
So, if I upgrade Joomla from 2.5.7 to 2.5.11, this missing option will appear properly?
10 years 10 months ago #4
by xillibit
Upgrading to Joomla! 2.5.11 is just be up to date
In synchronize users function in Kunena, there isn't a clean user cache function
- kurisutofue
- Topic Author
10 years 10 months ago #5
by kurisutofue
Maybe there is another way to solve fix my issue?
Currently, when I change user from administrator to moderator, it doesn't change in the frontend, however, it is sucessfuly recorded from the backend.
How to do for the front?
10 years 10 months ago #6
by xillibit
Can-you describe exactly how do you proceed to set an user like a moderator ?
- kurisutofue
- Topic Author
10 years 10 months ago #7
by kurisutofue
From Jommla backend, Kunena Module -> User management:
I select a user that I want set as moderator.
In first layer, his rank was Administrator. I changed to Moderator.
In Moderation layer, he was setted as No. I changed to Yes and selected a forum category he should moderate.
After save, nothing change in the frontend. He still be Administrator.
However, From the backend, he's Moderator.
Do you have any idea about it? Maybe I forgot something?
- kurisutofue
- Topic Author
10 years 10 months ago #8
by kurisutofue
Have you any suggestions?
10 years 10 months ago - 10 years 10 months ago #9
Replied by sozzled on topic How clean user cache
(1) There is no "clean user cache" feature in K 2.0,
(2).Do you want to know how to assign a moderator in Kunena? Is that really what this topic is about?
I am not sure I understand your question.
- kurisutofue
- Topic Author
10 years 10 months ago #10
by kurisutofue
I just want to know how to set a user as moderator, yes.
But the way I described below seems not to be the good one.
However, it seems there is nothing else?
Time to create page: 0.428 seconds
