The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question
K 1.7.2 -> K 2.0.4: all my topics are missing
tokenring wrote: Okay, just so I'm clear and you are too. Right now I am running J2.5.11 and Kunena 1.7.2. I am trying to upgrade from K1.7.2 to K.2.0.3 or K2.0.4.
Why don't you try upgrading from K 1.7.2 to K 3.0.0 instead?
I didn't realize that there was a newer version and 2.0.4 for Joomla 2.5. That is the version I am running. Even if that upgrade path is possible and exists, that doesn't explain the reason why on even making a smaller jump (upgrade) is causing my categories and topics to not show up.
I showed that the DB still has them and that the permissions look right ( I think so ). I would like to solve this, rather than picking another version to see if it helps.
That forces you to use higher than 5.2.17 (PHP). I'm not running that right now because of other modules/components in use.
