Kunena 6.2.6 released
Bug Image problems?
Your configuration report says otherwise.anfieldred wrote: I am using the standard kunena menu and my template is compatible.
Did you try posting the "missing images" here?sozzled wrote: This is not a defect if you are not using the standard K 2.0 Blue Eagle template. This is not a defect if you are not using the standard Kunena menu. This is not a defect if you have enabled all the Kunena integration plugins and all their options - especially if you don't have the required other software installed. And finally, if you have problems with using Kunena with the particular Kunena template that you have installed, please contact the developer to make sure that the template is compatible with K 2.0.2.
As far as Flickr and Photobucket are concerned, you may want to contact those two services or, alternatively, try posting the "missing images" here in our Playground category.
This sounds like the problem is related to a Javascript library issue. Please read msg #1 of Before you post your question, read this first ; your question is answered there.anfieldred wrote: No smilies show up either, indeed there isn't even a option to select them in the replies.
thanks to the team
- anfieldred
- Topic Author
- Junior Member
- anfieldred
- Topic Author
- Junior Member
(1) Posted your Photobucket or Flickr images on our Playground area? Do those images "disappear" after a while ... even on this site?
(2) Contacted the people from whom you purchased your Kunena template and asked them if their template is tested and fully-compatible with K 2.0.2?
(3) Contacted the people from whom you purchased your Joomla site template and asked them if their template is tested and fully-compatible with K 2.0.2?
(4) Tried the When all else fails, try this approach? Obviously there is a problem on your website that prevents you selecting smilies. The most likely candidate is "animacja script" thing (based around jQuery) on your site; I have no knowledge of the "animacja script" function you are using.
(5) Tried loading your plugins in a different order, as suggested when you read Common causes of Mootools (Javascript library) issues and Kunena (which is one of the links you will find in Before you post your question, read this first ).
ymages' problem is different
- anfieldred
- Topic Author
- Junior Member
But for the rest, I have a new compatible template for Kunena 2.02, but I am unable to use it yet as when I activate it, some of the font colurs are so light it makes it almost impossible to read. So I need to fix that so how. But when I was using it, it did not rectify the smilies, or insert image problems.
I am beginning to think I may have a problem with the Joomla template, though it is for J 2.5.
With regards number 4 and 5, I have looked at these but as of yet not found a solution.
Thanks for you time. I appreciate it.
