Kunena 6.2.6 released
Merged Problems with Gravatar avatar images
Thanks for your answers and help
Can you give us some more information about this "error", please?giorgio62 wrote: ... but if I disable the Gravatar plugin, I have an error when I do access to the main page of the Kunena forum.
... as opposed to what? If you turn on the Gravatar integration, people either will have a Gravatar account - and, possibly they will have a Gravatar avatar image - or they will have the "no avatar" avatar image. It's obbvious that people will have one or the other, isn't it? Did I misunderstand something otherwise intended?TKtemp wrote: ... so if you activate integration all users must have Gravatar account or no avatar.
I had exactly the same problem, which is now cured, I achieved it the following way....
1. Go to "Plug-in Manager" and ensure that the "Gravatar" plug-in is disabled.
2. Go to the Kunena control panel, and click on "Forum Configuration".
3. Click on the "Avatars" box.
4. Ensure that the "Use Avatars Gallery" box is set to "NO".
Now go to your "User Profile", click on "Edit" and you will discover an additional "Avatar Image" box. Click on this and you are able to "BROWSE" and "SAVE" your chosen Avatar.
Simples!!!!
Hope this helps!!
These steps should be unnecessary, in my opinion, but in these rare cases maybe this is something the development team should investigate further. Our difficulty is creating an environment that mimics the cases reported in this topic.Walander wrote: 2. Go to the Kunena control panel, and click on "Forum Configuration".
4. Ensure that the "Use Avatars Gallery" box is set to "NO".4. Ensure that the "Use Avatars Gallery" box is set to "NO".
I was just being a little sensitive, being a newbie and all that.
Gravatar is an external application, not installed on joomla site and should be only option for single user to use it. It is not the same as Community Builder and Jomsocial already installed on joomla site. How is designed now, Gravatar integration 'feature' is not usable for most of users.sozzled wrote:
- coder4life
- Kunena Contributor
- Thank you received: 50
