Kunena 7.0.8 Released
Question banner positions?
- 0c89e0889ba028c7c200254e
- Banned
Please read the Documentation
docs.kunena.com/index.php/Module_Positions
THANKS...
Added as described and workin perfect...
<positions>
<position>hornav</position>
<position>breadcrumbs</position>
<position>banner</position>
<position>left</position>
<position>right</position>
<position>top</position>
<position>search</position>
<position>topsl</position>
<position>user1</position>
<position>user2</position>
<position>user3</position>
<position>user4</position>
<position>user5</position>
<position>user6</position>
<position>user7</position>
<position>user8</position>
<position>user9</position>
<position>footer</position>
<position>syndicate</position>
<position>debug</position>
</positions>
Simply add another line(s) with <position>your module position</position> and place it in the order it will appear within the list.
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
Incorrect. You do not have to modify the XML file. After you have installed your banner/adsense module just type the name of the position into the "Position" field and make sure it is published to all pages. It should only be visible in Kunena.
Okay, is another option. I modified this file to the list of modulñe positions and work for me.
- grumblemarc
- Elite Member
- woonydanny
- Elite Member
- Thank you received: 22
you have to add the module positions within the templatedetails.xml
<positions>
</positions>
Easiest way is the way i wrote in the documentation wiki (same as what grumblemarc said)
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
