This category is for general discussion about the Kunena Project or this website.
Please use other categories for questions about problems that you may be having with your website.
Merged WYSIWYG editor for Kunena: How to allow HTML tags?
15 years 5 months ago - 15 years 5 months ago #78290 by dazzafact
I like the idea of this topic too, because it is easyer with formated Text!
Last edit: 15 years 5 months ago by dazzafact.
15 years 5 months ago - 15 years 5 months ago #79268 by c3da6df5dd8e8e868a652d04
I have problems with the Bbcode on my website. When I am writing text in a forum and I will make text bold, underline etc. then I see text en bbcode as well. After I submit the message and read the message then the text is bold, underline etc.
I thought that this is a problem on my website with mootools 1.2 but by surprise, while I am writing this text, I get the same problems.
On the left-under side I see the following internet explorer errors:
Row:467, Token:3, error: Not implemented. code:0, url:http://www.kunena.org/forum.newtopic
Row:2, Token:47606, error: Property or method not supported. code:0, url:http://www.kunena.org/forum.newtopic
On my PC I am using windows xp an on my laptop windows 7. In both case the problems are present.
Hopefully you can help me.
Regards,
Gert
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 50 seconds | Max execution memory: 32M | Max file upload: 12M
Joomla default template details : rhuk_milkyway | author: Andy Miller | version: 1.0.2 | creationdate: 11/20/06
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Last edit: 15 years 5 months ago by c3da6df5dd8e8e868a652d04.
15 years 5 months ago #79328 by sozzled
Replied by sozzled on topic Re: Problem with Bbcode
I'm sorry but I don't fully understand the problem. Perhaps a picture that shows us what you are experiencing would help.
As far as the Internet Explorer errors are concerned, these may (or may not) be related. IE often objects to many things that other web browsers do not object to. To help analyse this problem, do you have a test account on your forum that we can use.
15 years 5 months ago #79414 by c3da6df5dd8e8e868a652d04
I was meaning the following: Is it possible to have a wysiwyg-editor for this forum instead of the putting-code-via-the-board-codes-around-the-letters?
15 years 5 months ago #79431 by sozzled
Thank you for the clarification, Gert. I have merged your topic with an existing topic that discussed WYSIWYG editing and Kunena and I hope that this topic helps you understand why it is not currently possible to achieve what you have asked.
15 years 5 months ago #79681 by c3da6df5dd8e8e868a652d04
Thank you for your reply, everything is now clear for me. I understand your version
and the discus about the WYSIWYG editing, and also that it is not currently possible to achieve what I have asked.
I find that Kunena did a great job with making this forum and I'm happy about it. Specially when I saw the possibility of the preview pan below and on the right.
Until now I thought that I had a mootools problem, because I first didn't saw the bbcode icons. That is now, with the upgrade plugin of mootools and configuration of my template, solved. All is working now and in Dutch, only the roles en help I had to translate in Dutch.
Regards en thanks,
Gert
From the Netherlands
Time to create page: 0.304 seconds
