Kunena 6.2.6 released
Question Joomla legacy mode and Kunena
Yes, but i don't use a fresh installation of kunena. I used an old version (1.0) that had not any problem with legacy. I try to update with legacy and kunena works. But now, simple, i would remove legacy plugin.. and i can't without broke kunena...sozzled wrote: What "older" version of Kunena are you talking about? At this time our primary interest concerns K 1.6.x.
sozzled wrote: K 1.0 requires J! 1.0 or J! 1.5 with legacy mode. Please read the article K 1.0/K 1.5 Technical Requirements
I thank you for your kindly answer, as usual, but now i have kunena 1.6.3, as i writed
I spoken about this story in this post, becouse, I think, that cause of my problem is that i have very old version that i updated in the years from 1.0 to 1.5 ant then 1.6!
In this amarcord post you tell me to update
www.kunena.org/forum/135-k-15-installati...-language-im-reading
but now, after every update, i can't disable plugin legacy! And i don't use component, module,template and plugin that requires legacy. If I disable, all site works, but kunena has a white page....
I would try to delete a kunena folder that has this name: "legacy". It is a strange folder with some old images......... Do you think that this can help me to solve? I'm starting to think that i'm not very lucky with kunena...
I think you do. I've shown you, (in msg #5 in this topic) how to find it (or them). You have to find it (or them).I don't use component, module,template and plugin that requires legacy. If I disable, all site works, but kunena has a white page
If you need help finding old J! 1.0 components, template, languages, plugins or modules, please start a new topic in the Miscellaneous, off-topic and general Joomla category and someone may be able to help you. It would also help if you posted your K 1.6 configuration report with your question.
Ok. I'm very happy becouse i solved deleting old images in media/kunena/attachments/legacy )))))))))))))))))))))))))))))))))))))))
I have similar case with legacy mode on Kunena.
In my case forum has been updated from 1.6 to 1.63. With 1.6 I used legacy mode because I had some old modules on my Joomla. Now all old modules are removed but I can not turn of legacy mode if Kunena is on. If I turn off Kunena in install -> components Joomla works with out legacy mode, but with Kunena switch on I get message "Direct Access to this location is not allowed."
I've try switch off all my components and only with out Kunena Jommla works fine.
All components/modules/plugins on installer page are green.
What else I have to check?
sozzled wrote: If you need help finding old J! 1.0 components, template, languages, plugins or modules, please start a new topic in the Miscellaneous, off-topic and general Joomla category and someone may be able to help you. It would also help if you posted your K 1.6 configuration report with your question.
When i disable Legacy plugin i'm getting this error: dirrect acces to this location is not aloved. All components, modules, plugins and template compatibility with joomla 1.5. When i disable kunena component everything works fine, no errors. I use standart kunena template. What's the problem and how fix this?
