Kunena 6.4.9 & Kunena 7.0.1 Released
The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question Kunena NL Ultimate V1.5.9
Frontend
Warning: Error parsing
\server\xampp\htdocs\cockers\components\com_kunena\JoniJnm_Plugins\gracias\language\nl-NL.ini on line 28 in
\server\xampp\htdocs\cockers\components\com_kunena\JoniJnm_Plugins\api.php on line 506Warning: Error parsing
\server\xampp\htdocs\cockers\components\com_kunena\JoniJnm_Plugins\api.php on line 114Warning: Invalid argument supplied for foreach() in
\server\xampp\htdocs\cockers\components\com_kunena\JoniJnm_Plugins\api.php on line 115* Recente Discussies
* Home
* Regels
* Help
Backend:
\server\xampp\htdocs\cockers\components\com_kunena\JoniJnm_Plugins\api.php on line 506 Ik heb nog steeds een aantal problemen met de Avatars:
- Bij het wijzigen van de Avatar krijg ik nog steeds de melding:
* JFTP::write: Bad response
* JFTP::delete: Bad response
Maprechten e.d. staan goed op 755.
Na een refresh is de nieuwe Avatar wel gewoon zichtbaar!
Na update naar de v2 versie krijg ik deze fotmeldingen:
Frontend
Warning: Error parsing\server\xampp\htdocs\cockers\components\com_kunena\JoniJnm_Plugins\gracias\language\nl-NL.ini on line 28 in
Warning: Invalid argument supplied for foreach() in\server\xampp\htdocs\cockers\components\com_kunena\JoniJnm_Plugins\api.php on line 115
* Home
* Regels
* Help
Backend:
Deze problemen had ik ook, dat komt omdat er een foutje staat in de gracias plugin
zoek nl.NL.ini op in de volgende map: (site)/components/com_kunena/JoniJnm_Plugins/gracias/language en ga naar deze regel:
points_author_d==Voeg jomsocial userpoint toe aan post's auteur
Haal daar één = teken weg. denk dat dat een typfoutje was.
Groeten
Vreemd dat ik die melding nooit gezien hebt. Bij mij gaf hij geen fouten tijdens installaties.
Gr Jelle
- Soulmaster
- Junior Member
