Kunena 6.4.8 Released
Question Kunena NL Ultimate V1.5.9
16 years 7 months ago #11 by 810
Replied by 810 on topic Re:Kunena NL Ultimate
grumblemarc wrote:
You are posting this in an English language forum. Please provide an English translation in the posts or I will need to move this to the appropriate language forum. Thank you.
The Dutch section is disabled, so i did it in this section
The topic has been locked.
16 years 7 months ago #12 by Lintzy
Replied by Lintzy on topic Re:Kunena NL Ultimate
You need a moderator for the dutch childboard to enable it.
16 years 7 months ago - 16 years 7 months ago #13 by 810
i Send a pm to johnnydement a month ago, but no answer.
And i have edit the text now with english translation
Last edit: 16 years 7 months ago by 810.
16 years 7 months ago #14 by Lintzy
I am sure, Johnnydement did not read it, or forgot it. Sorry about that, i will remind him.
16 years 7 months ago #15 by johnnydement
Replied by johnnydement on topic Re:Kunena NL Ultimate
Yes sorry, jomsocial has a strange way of ordering messages... it was still unread on page 2 or 3 :blush:
I will open it this afternoon ;)
16 years 7 months ago - 16 years 7 months ago #16 by 810
Versie 1.1.4
Compatibiliteit: Joomla 1.5 Legacy
Zojuist de versie bijgewerkt,
*bbcode 109-11 toegevoegd
*Upgrade van 1.0.5 tm 1.0.8 naar 1.0.9 verbeterd
Download: www.newf1.nl/com_kunena_v1.0.9_b1231_2009-04-10.zip
Sef Edition: Voor mensen die met sef werken (artio joomsef & sh404SEF)
Download: www.newf1.nl/com_kunena_v1.0.9_b1231_2009-04-10_sefedition.zip
16 years 7 months ago #17 by aluher
Replied by aluher on topic Re:Kunena NL Ultimate
wow.. great job. love your work!!
ga t vanmiddag installeren op mn site. erg bedankt voor de vele moeite die je er in steekt!!
16 years 7 months ago #18 by 810
your welcome,
Graag gedaan
16 years 7 months ago - 16 years 7 months ago #19 by Mixx
Replied by Mixx on topic Re:Kunena NL Ultimate
* JFolder::files: Het pad bevat geen verwijzing naar een geldige map of de map werd verwijderd.
* JFolder::folder: Het pad bevat geen verwijzing naar een geldige map of de map werd verwijderd.
* FOUT: kon geen Joomla! XML setupbestand vinden in het pakket.
Warning: array_merge() [function.array-merge]: Argument #1 is not an array in /home/******/domains/*****.org/public_html/libraries/joomla/installer/helper.php on line 142
Warning: array_merge() [function.array-merge]: Argument #2 is not an array in /home/******/domains/******.org/public_html/libraries/joomla/installer/helper.php on line 142
Warning: Invalid argument supplied for foreach() in /home/******/domains/******.org/public_html/libraries/joomla/installer/helper.php on line 187
Ik krijg deze error als ik deze component probeer te installeren. Ik heb geprobeerd om het uit te pakken van tevoren, direct vanaf de link te installeren en natuurlijk gewoon te installeren. De engelse versie kan ik wel gewoon installeren.
Last edit: 16 years 7 months ago by Mixx.
16 years 7 months ago #20 by 810
Vreemd, kan je de bestanden over de engelse versie zetten, misschien lukt het dan, of download hem opnieuw, misschien is het downloaden niet goed gegaan.
Time to create page: 0.544 seconds
