Question Displaying forum topics on the mobile problem
I have a small problem with displaying topic posts on mobile. kmsg-header - containing topic name is covered by profile info with avatar. It is a minor thing but I would like to fix it. I hope that maybe someone experienced similar problem and fixed it. Thank you in advance for you help,
Wojtek
Please see the attachment
- WolfgangOWL
- Senior Member
See here
- WolfgangOWL
- Senior Member
On mobiles it will look like this:
The solution will only work for Crypsis and not for Blue Eagle 5.
- WolfgangOWL
- Senior Member
- WolfgangOWL
- Senior Member
Is your solution for Crypsis generally? Why you not write it as suggestion on Github? We have already some proposals accepted from you and inserted in Kunena.
- WolfgangOWL
- Senior Member
Yes, this is for Crypsis generally. I implemented it only for b2. Unfortunately, I'm not familiar with Github. I just created a Github account and will have to see how it works. Maybe I'll need some assistance from you.
- WolfgangOWL
- Senior Member
Rich, I don't have the time and nerve to fiddle with Github at the moment. Maybe you can put it on Github and give me the link so I can see where to publish it.
Styling to put in custom.less:
Files to be modified (see attachment):
/components/com_kunena/template/crypsis/layouts/message/item/default.php
/components/com_kunena/template/crypsis/layouts/search/results/row/default.php
/components/com_kunena/template/crypsis/layouts/topic/edit/history/default.php
- WolfgangOWL
- Senior Member
You're welcome. I see that it's already merged and applied to this forumrich wrote: Thank you!
