Question Public Forum Group Premissions?
17 years 9 months ago - 17 years 9 months ago #724 by mstephan
I understand that the developers are integrating JomSocial's group with kunena so that the group can have a forum discussion board.
But I was wondering if there was a way to set published forums on the public forum board to only be viewed by those in a specific group?
I'm unfamiliar with JomSocial but I am planning on purchasing it soon. My current site runs CB, GJ and FB. In order for the groups to have a "private" forum, I had to do a minor hack.
Will this be needed for JomSocial?
With my current site, the only way to get to the group's board is to click group forum from the group's page.
I would like to see the group forum integrated with the group but also be able to view the group forum from the public forum if you are a member of the given group.
Visually, when you scroll down on the main forum board, I'd like there to be group sections, maybe similar to JomSocial's group categories, that has their integrated forum and unless you are actually in a group, the forum would be invisible.
Is this possible?
Last edit: 17 years 9 months ago by mstephan.
17 years 9 months ago #971 by mstephan
Perhaps I was unclear or posted this in the wrong section?
17 years 9 months ago #976 by aniphreak
its unclear
17 years 9 months ago #979 by mstephan
baah, nevermind.
17 years 9 months ago #981 by whouse
I'm sorry that you haven't received a satisfactory answer, or even a real answer at all. I can't really give you one either as I do not have a copy of jomsocial for testing so your answer will most likely have to come from one of the developers. Problem is that they are swamped answering many support questions as well as churning out code as we try to stabilize the old FB codebase with many of the bugfixes necessary to do so.
Hopefully they will be able to soon have a look at your question and give you an answer. I will point this post their way and I'm sure as soon as one of them has time, he will let you know something.
Thanks.
17 years 9 months ago #1006 by johnnydement
As far as I understand, you want for kunena to pull groups from jomosocial, and when a new group is created, for it to create a private subforum for it?
Well, our integration does not yet that (neither any other one that I know), it's something we would like to do, but there are more urgent issues to be adressed, also, is something we want to take care of using our new API, that is till on the works.
