- Thank you received: 3
Kunena 6.2.6 released
Question Kunena & CB1.2 tabs / new field problem
- philiplardner
- Topic Author
- Junior Member
Now don't touch it again or it might break!! :woohoo:
Phil.
KatiaB wrote:
@Sozzled: when I unpublish cb.simpleboardtab all the other tabs and fields related to forum in CB become unabled. Kunena still works on the site, but nothing shows up in the profiles anymore. Any thought?
- grumblemarc
- Elite Member
- Still making trouble
- philiplardner
- Topic Author
- Junior Member
Yeaaaah, it's all working great now!!!! (doing a gratitude dance now:laugh: )
Thank you sooooo much for making my day Phil!
Hi Katia,
One other thing I forgot about until just now - I also got my ISP to upgrade my server from PHP4.x.x to PHP5.1.6. I don't know if this had anything to do with my solution, but it is possible!
Phil.
Don't know anything about servers and PHP but mine told me mine is supported by PHP5 already. So I guess it has nothing to do with my solution :lol:
Katia
Only thing i dont seem to get to work is for the forum to show within groupjive. Which files of Kunena do i need to edit to make it work?
I really appreciate your help!!!!
ili
Installation:
Joomla 1.5.9
Php 5x
com_groupjive_v29a
gjplugin_integration_fireboard_v1.7e1
plug_groupjivetab_v.1.6b
Just in case somebody else is looking for the same thing. Here is what i did. NO guarantee it will work for you too
1. back up files and DB
2. uninstall fireboard
3. install newest Kunena version
4. disable old GJ Fireboard plug in in CB -> plugins
5. install GJforum - the extended forum plugin available here www.groupjive.org/index.php?option=com_d...iew&gid=24&Itemid=59
6. enable plugin and enter correct category for kunena forum.
Hope this helps somebody some time!
ili :woohoo:
- In The CB Plugins section, Unpublish the Fireboard Forum Plugin
- If it's installed, uninstall the Kunena Forum Plugin
- Install the Kunena Forum Plugin
- Rename the file /publichtml/.../components/com_comprofiler/plugin/user/plug_cbsimpleboard/cb.simpleboard.php
That worked for me and I could add new fields again.
I tried this out but it doesn't completly work.
Explaination : I'd like to have forum activity with updated plugin in CB profiles AND have Kunena profiles linked to CB (not using K profiles).
Point is, with original forum integration plugin, forum activity is not as I'd like it to be (buttons not working, sliders not right ones).
-> I can fix it with the new forum activity plugin, unplishing and renaming old one.
However, once that's done, Kunena cannot link profiles to CB...
Seems that both wishes aren't compatible...
Any idea how to solve that ?
I googled this issue but this thread seems to be the most advanced one.
Installation :
CB 1.2.1
J! 1.5.14
Kunena 1.5.6
