- Thank you received: 11
Question [Merged topic] K 1.6 needs "autodetect" for integration with JomSocial
Process went without problems.
I recreated all the main menu links but whenever I select any of them I get blank pages.
With debugging on nothing came to light but when I set error reporting to maximum I get this :
Fatal error: Call to a member function getAllowedCategories() on a non-object in /home/safnet/public_html/components/com_kunena/class.kunena.php on line 517
Heres the output from report configuration settings :
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 2000 seconds | Max execution memory: 128M | Max file upload: 64M
Kunena version detailled: Installed version: 1.6.0-RC1 | Build: 3173 | Version name: Kujadili | Kunena detailled configuration:
board_title S.A.F Community board_offline 0 board_ofset 0 offline_message <h2>The Forum is currently offline for maintenance.</h2>
Check back soon!enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 20 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 1 disemoticons 0 template default showannouncement 1 avataroncat 1 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 700 rteheight 300 enableforumjump 1 reportmsg 1 username 0 askemail 0 showemail 0 showuserstats 1 showkarma 0 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 0 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 5 mailmod 0 mailadmin 0 captcha 1 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 imageprocessor gd2 avatarquality 80 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 4096 imagewidth 4096 imagesize 10240 allowfileupload 0 allowfileregupload 1 filetypes zip,txt,doc,gz,tgz,pdf,png,jpg,jpeg,gif,xls,docx,xlsx filesize 10240 showranking 1 rankimages 1 avatar_src fb_profile pm_component userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 0 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory showstats 1 showwhoisonline 0 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1186 rules_link help_infb 0 help_cid 1 help_link www.bestofjoomla.com/ showspoilertag 1 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type thread rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_word_count 0 rss_old_titles 1 fbdefaultpage recent default_sort asc alphauserpoints 0 alphauserpointsrules 0 alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 1 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system old_ord post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access jomsocial integration_login jomsocial integration_avatar jomsocial integration_profile jomsocial integration_private jomsocial integration_activity none boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankysoustats 1 popthankscount 5 mod_see_deleted 0
You should see errors in the apache error log.
Ive got JS uninstalled right now to do the horrible upgrade process it requires every time theres a new version, I had 1.6.289 but I am planning to go to 1.8.7
Could it be this that is the cause? (uninstalled just now)
Switched to autodetect and its happy, many thanks for the clue.
Im not sure that autodetect is needed for JS, its more at the time I encountered the error and posted the integration settings in my Kunena had retained the previous "Jomsocial" specific settings from my Kunena 1.5.9 install when I had Jomsocial 1.6.289 uninstalled in preperation to reinstall 1.8.7, I merely switched to "Autodetect" and found that reverted Kunena to using its own system in the abscence of Jomsocial.
Further, now Ive just reinstalled JS 1.8.7 Kunena has now switched from its on system back to using the JS information while the integration settings are still set to "autodetect".
Happy to have helped
- zonedabone
Fatal error: Class 'CFactory' not found in /home/rivertraders_/rivertraders.net/administrator/components/com_kunena/libraries/integration/jomsocial/activity.php on line 65
Other users tell me they have no errors, and the post still is put on the forums correctly.
This message contains confidential informationhtaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 90M | Max file upload: 7M
board_title RT Forums board_offline 0 board_ofset 0.00 offline_message <h2>The Forum is currently offline for maintenance.</h2>
<div>Check back soon!</div>enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template default showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 0 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 imageprocessor gd2 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 2000 allowfileupload 0 allowfileregupload 1 filetypes zip,txt,doc,gz,tgz filesize 120 showranking 1 rankimages 1 avatar_src fb_profile pm_component userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 0 rules_cid 1 rules_link www.kunena.com/ help_infb 0 help_cid 1 help_link www.kunena.com/ showspoilertag 1 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 0 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type thread rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_word_count 0 rss_old_titles 1 fbdefaultpage categories default_sort asc alphauserpoints 0 alphauserpointsrules 0 alphauserpointsnumchars 10 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system old_ord post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access joomla integration_login joomla integration_avatar kunena integration_profile kunena integration_private none integration_activity jomsocial boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankysoustats 1 popthankscount 5 mod_see_deleted 0
After i Post i get this.
Fatal error: Class 'CFactory' not found in /home/www/web303/html/administrator/components/com_kunena/libraries/integration/jomsocial/activity.php on line 65
or on line 28.
On line 28/65 is: CFactory::load ( 'libraries', 'userpoints' );
My Kunena version is Kunena 1.6.0-RC1
About jomSocial: I have no idea how to check the type of version of jomSocial. If that matters i need help about that too.
Thanks alot.
Tobi
It's somthing about the Forum Config.
I changed the settings on integration: Activity Notifications
And changed it to Auto Detect.
And now, its now longer gets a error after a Post.
It's actually quite simple. Or i'm totally wrong :blink:
Supplements are welcome.
regards
Tobi
