Question Kunena plugin for sh404SEF
- Philip Roy
- Senior Member
I found files here....
www.joomace.net/free-downloads/sh404sef-extensions/kunena-1-0
...hit the big "download" button on the right....but this says "1.0", but there was a "1.0.1" release on the other site...so it's all a bit confusing.
1.0.1 is causing issues for me...it doesn't run natively and some multipage threads don't work in terms of navigating to another screen.
Phil
- Philip Roy
- Senior Member
www.joomace.net/free-downloads/sh404sef-extensions/kunena-1-5
But it's still version 1.0 and not 1.0.1
Phil
tks for your answer
- Philip Roy
- Senior Member
So for you, the author of the plugin that we're using, may or may not have written a fireboard plugin, which you may or may not be using...therefore, we can't answer. Or more likely, the answer is...no.
Phil
How do I put the number of post alnome next subject?
almost all plugins by this autor have a problem. he still says they work good also in front of opposite evidence.
9$ wasted
Change the settings you've copy-pasted from ReadMe.txt file.
evilita wrote:
this sh404 plugin doesn't work correctly when moderating posts (approving or removing function doesn't work).
9$ wasted
ALL moderation functions (including approving and removing) works fine with the last version of our plugin, check our test site. If you cant manage sh404SEF plugins to work this is not our foult AND our Kunena plugins are free, a little bit flawless plz.
AceSEF - Joomla! SEO Suite
- Philip Roy
- Senior Member
I'd have to respectfully disagree sorry. I get 404 errors during the deletion process every time.
Phil
Kunena 1.0
Kunena 1.5
O.T. the plugin i buyed was for eventlist and that is not working too. so be aware from their products. they didn't give me any support for their products. they said i did not configure well their plugin but there are only 2 options to configure it and was not working in any way. there are serveral free plugin for sh404 working better (unfortunatly not completely good) for your components.
