Question Kunena plugin for sh404SEF
14 years 9 months ago #11
by lowster11
Replied by lowster11 on topic Re:Kunena plugin for sh404SEF
I got it to work on my forum, what I did was rename the com_fireboard.php file in /components/com_sh404sef/sef_ext to com_kunena.php and then I put a empty file named com_kunena.php into components/com_sh404sef/meta_ext
You can see here...forum
The topic has been locked.
14 years 9 months ago #12
by lowster11
Denis -
how do you fix this with your plug-in?
<meta name="keywords" content="Test, Main Forum, Kunena, Demo 2" />
<meta name="description" content="denis dulici, sh404sef. Test - Main Forum - Welcome Mat - Kunena" />
14 years 9 months ago #13
by dulici
AceSEF - Joomla! SEO Suite
Replied by dulici on topic Re:Kunena plugin for sh404SEF
I've updated my plugin, now compatible with Kunen 1.5 too.
14 years 9 months ago #14
by electik
Replied by electik on topic Re:Kunena plugin for sh404SEF
Hello Denis,
With your plug-in, I can't delete and edit a post
Thanks for your help
- Philip Roy
- Senior Member
14 years 9 months ago #15
by Philip Roy
Replied by Philip Roy on topic Re:Kunena plugin for sh404SEF
Yep, I have the same issue on both my sites.
Phil
Phil
14 years 9 months ago #16
by dulici
I've just updated my plugin, here you can see it in action:
www.denisdulici.com/demo2/kunena.html
14 years 9 months ago #17
by Edu
Replied by Edu on topic Re:Kunena plugin for sh404SEF
Hi Dulici,
I have just tried your updated plugin. My forum had some problems with "reply" buttons but now it goes perfect.
Now, my problem is that it doesn't use "meta" info from "jos_sh404SEF_meta" table.
I have tried replacing "fireboard" for "kunena" in "newurl" column but I haven't got anything.
Thanks a lot for your effort
- Philip Roy
- Senior Member
14 years 9 months ago #18
by Philip Roy
Appears to be working for me too. Thanks for the quick response...well worth a donation!
Phil
Phil
- Philip Roy
- Senior Member
14 years 9 months ago #19
by Philip Roy
I'm finding two issues with the plugin.
First, on a site that I have installed the 1.5 files, if I disable the legacy plugin, everything works, except when users post. In this instance, the forum fails to load completely and users are left with a blank page with only the start of the site template. I've had to re-enable the legacy plugin for the site.
The other issue is the "too many redirects" error on some links...such as this one, that will result in a redirect error if you try to access the thread....
www.nzmac.com/forum/internet-comms-and-n...-keeps-changing.html
Cheers, Phil
Cheers, Phil
14 years 8 months ago - 14 years 8 months ago #20
by barthle
Replied by barthle on topic Re: Kunena plugin for sh404SEF
Is there anyone in the world who could really find his way in this maze of circular links? I struggled half an hour, filled out the order form, followed the every steps, but couldn't find a way to locate the file. Is this a joke or something? I never seen such a bad design. Links are just loops, they keep you circling around the same page. I started with
www.denisdulici.com
and ended up another site after passing through the other stops. Every page says Click Here To Download file but it just takes you to another list, you again click but still another list page. I feel dizzy. Need a cigarette. Thanks god I didn't try this for other paid Sef404 extensions
Last edit: 14 years 8 months ago by barthle.
Time to create page: 0.456 seconds
