Kunena 6.4.9 & Kunena 7.0.1 Released
The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question Kunena latest posts module - BACKPORTED FOR JOOMLA 1.0
16 years 5 months ago #27157 by xabo
Replied by xabo on topic Re:mod_kunenalatest
Do anyone got a updated link to download this mod? The link found on extensions.joomla.org/extensions/extensi...orum-extensions/7334 doesnt work.. Sad, since i realy want this mod.
Thanks in advance.
The topic has been locked.
16 years 4 months ago #28545 by Ratman
Replied by Ratman on topic Re:mod_kunenalatest
I use the following workaround:
Let´s say you have a forum with several Categories, some of them are restrictetd to "authors" (and above).
Publish one "Latestposts"-Module and set the permission to "Public" or "Registered". In the "Do not show only these categories"-field enter the forum-IDs you do not want to show to all users. In the module-view, make a copy of this modul, set the permission to "Special". In the field "show only these categories" enter those forum-IDs you have excluded in the first module. Place the module beneath the first modul without showing the titlebar, so it should fit right beneath the first module, this may depend on the template. Just play araound with the settings for the number of posts shown etc.
It´s not perfect, but it´s better to show all headers to all users, where restricted users get errormessages when they click on a "wrong" thread.
16 years 4 months ago #28695 by Nebiru
Replied by Nebiru on topic Re:mod_kunenalatest
My solution is to compare the $user->gid with the pub_access
to do this replace lines 123 - 134 in .../modules/mod_kunenalatest/helper.php
$i = $show_pub + 2 * $show_reg + 4 * $show_spe; switch ($i) { case 0: $sql_access = 'AND false'; break; case 1: $sql_access = 'AND c.pub_access in (0)'; break; case 2: $sql_access = 'AND c.pub_access in (18)'; break; case 3: $sql_access = 'AND c.pub_access in (0,18)'; break; case 4: $sql_access = 'AND c.pub_access in (19,20,21)'; break; case 5: $sql_access = 'AND c.pub_access in (0,1,19,20,21)'; break; case 6: $sql_access = 'AND c.pub_access in (-1,18,19,20,21)'; break; default: $sql_access = ''; }
with the following code:
switch ($user->gid) { case 0: $sql_access = 'AND c.pub_access in (0)'; break; case 18: $sql_access = 'AND c.pub_access in (0,1,18)'; break; case 21: $sql_access = 'AND c.pub_access in (0,1,18,19,20,21)'; break; case 25: $sql_access = 'AND c.pub_access in (0,1,18,19,20,21,25)'; break; default: $sql_access = 'AND c.pub_access in (0)'; }
And it seems to work.
16 years 4 months ago #28881 by Cosworth
Replied by Cosworth on topic Re:mod_kunenalatest
Nebiru this works fine save for the forums created with groupjive for instance that have pub_access = 30. Now the correct thing to do here would be to initialize $fbsession and access $fbsession->allowed giving you the allowed category id's. Then you could replace the switch statement with:
$sql_access = 'AND c.id in '.$fbsession->allowed
Unfortunately I haven't been able to do that.
16 years 3 months ago - 16 years 3 months ago #31957 by sarkit
Replied by sarkit on topic upgrade Latest post
hi,
i'm using a module..where i can show forums latest post at home..which looks like -
but i want to my latest post like this way -
see..how synchronized the 2nd one is..is there any module or any upgrade version uploaded yet..?
Last edit: 16 years 3 months ago by sarkit.
16 years 3 months ago #32156 by sarkit
Replied by sarkit on topic Re: upgrade Latest post
no reply.. :(
Time to create page: 0.349 seconds
