Kunena 6.4.8 Released
Question Kunena latest posts module - BACKPORTED FOR JOOMLA 1.0
16 years 10 months ago #11 by taurgis
no problem :-)
The topic has been locked.
16 years 10 months ago - 16 years 10 months ago #12 by fuqaha
thanks taurgis~!
*im using JS, the avatar dint work. :dry:
Last edit: 16 years 10 months ago by fuqaha.
16 years 10 months ago #13 by taurgis
Mods can delete this topic if they want. I only ported the thing over since no one had done it yet.
Original author posted it so :)
16 years 10 months ago #14 by johnnydement
No need to delete, we're grateful for the quick fix, althought we will recommend now to keep on jerry one as he's former author.
For next time, make sure you contact former author first ;)
Thanks!
16 years 10 months ago #15 by jbh142
Noe of the latest post modules work with 1.0.11 stable. Does anyone know of a module that is working with Kinena and joomla 1.0?
I hope I dont have to convert back to the old fireboards.
16 years 10 months ago #16 by onki
Replied by onki on topic Adapt mod_fblatest for Kuena
Hi
Yesterday I switched over from FB to Kunena after the announcement, that FB is discontinued.
My problem was, that I am using the latest post module on my website which always guides to the FB forum when clicking on new posts.
I needed to adapt the current module to link to the Kunena forum which is very easy to manage.
Just change the component name mentioned in line 58 of mod_fblatest.php located in folder /modules/mod_fblatest/ to "com_kunena" so that the line looks like that:
$componentname = 'com_kunena';
This will guide all entries to the kunena component instead of fireboard.
I hope this info is useful for you. Maybe some else has discovered this before.
Best regards
Onki
16 years 10 months ago #17 by woonydanny
There is a new Kunena Latest Posts module by jerry on this site. Best to use that one for compatibility down the track, as no doubt kunena will start branching away from fireboard and then your one wont work.
Jerry's one has i think all the features of other latest post modules and will no doubt be the main one continued in development i would assume.
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
16 years 10 months ago - 16 years 10 months ago #18 by core2
The latest post module from Jerry depends on Joomla 1.5.
The mod presented by Onki apply to Joomla 1.0.
Anyway the module from Jerry rocks! thread with Jerry's latest post module .
Visit the Kunena documantation .
Last edit: 16 years 10 months ago by core2.
16 years 10 months ago #19 by aniphreak
yes it really rocked!
16 years 10 months ago - 15 years 11 months ago #20 by JoniJnm
Last edit: 15 years 11 months ago by JoniJnm.
Time to create page: 0.403 seconds
