Question relative posts hack 0.1 beta
Probably this is the trouble...
P.S.I've changed that file but nothing again.
Can you send me YOUR view.php file? Please. :blush:
i did not try ut 1.015.
did you run the queries at my first message in your phpmsqladmin?
But... the trouble is that I tried to install it to 1.015 so I am sure that is the problem.
You know, I made "tag" hack without mistakes and I thought that it (related posts I mean)
would be alright also.
Some strings of 1.015 I think differ from those ones of 1.5
And queries also...
Well, my question is:
Will you be so kind to provide Joomla version 1.015 database queries and pieces of hack? of course, if you can.
to this:
i guess it will work...
It works!
I have added your hack into Kunena JoniJnm Edition, thank you!
PD: You should change
if ($topics_only = 1)
$parent =" AND parent=0 ";
By:
$parent = ($topics_only == 1) ? " AND parent=0 " : "";
- jeanpier biasiolo mérchan
Query was empty
I wanted to tell you that ami gives me this error, :S
Query was empty
did you copy codes from message directly or quote?
