Kunena 6.4.8 Released
Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
- wingnut144
- Senior Member
Is there something else I need to do to get this to work??
- wingnut144
- Senior Member
How can I make the avatars links to the profile? or the message?
Many thanks,
B.
The fix can be found here.
www.jomsocial.com/webforum/viewtopic.php...7644&start=30#p55717
After applying this patch, you can edit the jomsocial status and use this module properly.
You need to use the %A attribute to display the avatar. If you mouse over the item format, it will give you a list of all the parameters.
yes, thanks, i know that (I have made my div based template for that...)
I need to know just is that possible to make the avatar linked to the profile?
(as default just show the avatar, but cant click on it...)
Many thanks,
B
- Soulmaster
- Junior Member
is what i'm seeing before i see the discussions.
I have an old version of JomSocial, could this be the problem?
