Kunena 6.4.8 Released
Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
Wait for Kunena 1.5.4, which should fix JQuery issues.Hi Guys,
Yes the problem still persists.
The developer of Mosetstree has found a "partial" solution for it by changing some lines in class.kunena.php which is a Kunena core file as is shown in the link that I have given. So some change may be required in the kunena as well.
Something in Kunena components prevents Kunena Latest module to be displayed inside a Tab when Mosetstree Latest module is active on the same page or vice versa.
These two module were working properly together. Either new native version of Mosetstree 2.1 or native version of Kunena 1.3.5 has corrupted something.
Oh, I am definetaly waiting. When is Kunena 1.5.4 going to come out?Andreaz wrote:
Please wait for Kunena 1.5.4 which patches some JQuery errors.Hey,
I really love your module, but I have some problems with it. When Kunena Latest is enabled and I try to use Slick RSS or Thick RSS modules my website goes blank. This only happens in pages with articles or in articles category/section pages. In forum or gallery both Kunena latest and RSS modules work without breaking the page...
Oh and it only happens if Kunena Latest module is tabbed. I am using Dinamod Tab Modules.
He suggested to make the same change in one of the mosets tree file as well and that solved the problem.
I am not a programmer but I suppose that two function calls shouldn't make directly, first it should be checked if they are already called somewhere else.
Yes, you can publish one module for these people. In this module, you can set Access Level: Special.I it possible to show the special access posts only to the special access people and not to all registered people?
- bytebandit01
- Senior Member
a link to user profile when you click the avatar would also be a great addition
Ever since I upgraded to 1.5.3 I have had errors in the latest post module. Does anyone know if there is a fix for this?
The discussion topic for your questions is Kunena latest posts module . Please use it instead of creating a separate topic.
