Kunena 6.4.8 Released
Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
thanx for reporting, solved in version 1.0.43for html error
i think i fix that
at helper.php line 242 $s = str_replace('title=""', 0, $s); comment it
validator.w3.org/check?uri=http%3A%2F%2Fwww.lundro.al%2F
Thanks for your quick answer and actions. I'll be able to test tonight at home on my test server and keep you informed about any issue or even better if everything is solved.
Kind Regards,
Denis
Should be solved in version 1.0.42 released right now. Thanks for reporting.
Hi Jerry,
Just in case you already released 1.042, could you please give a link to that version?
If it is not yet done no problem I will just see it later
Cheers,
Denis
Hi Jerry,
Cheers,
Denis
Mahalo,
JBHawaii
Looks like it was a hard day working onto different issues... already 1.0.43...
Thanks A LOT Jerry, I'm going to test the 1.0.43 right now.
Mahalo,
JBHawaii
I think I'm very closed to instal the new kunena version to the final website now.
Thanks a lot for your help!
Kind Regards,
Denis
