Kunena 6.2.6 released
Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
From this it works only on kunena 1.0.8 : extensions.joomla.org/extensions/communi...252dons/7334/details
Actually no, it works from 1.0.8 up... also with 1.5.1a up. Tested with 1.5.3 and works nicely.Hello,
Interesting. What's your platform? OS and PHP version? Kunena version?Hello,
I tried Kunenalatest mod v1.0.40 and if I enable this module then I get the following error message:
Warning: require_once(componentscom_kunenalibkunena.communitybuilder.php) [function.require-once]: failed to open stream: No such file or directory in C:Program Filesxampphtdocsailesdesignesmodulesmod_kunenalatesthelper.php on line 17
Fatal error: require_once() [function.require]: Failed opening required 'componentscom_kunenalibkunena.communitybuilder.php' (include_path='.;C:Program Filesxamppphppear') in C:Program Filesxampphtdocsailesdesignesmodulesmod_kunenalatesthelper.php on line 17
I guess the module is not written for this kunena component?
Thanks in advance for your support.
Kind Regards,
Denis
Do you have file in components/com_kunena/lib/kunena.communitybuilder.php ? (should be there after installing kunena 1.5.3 or Kunena 1.0.10)
Do you have community builder working? Try to disable community builder in Kunena component, if the module works in that settings.
I installed the new Kunena module localy to my computer. (Before installing the module to the final web site...)
OS: Windows XP Pro
Joomla: 1.5.11
PHP: 5.2.8
DB: 5.1.30-community
Kunena: 1.5.3
Yes, the file "kunena.communitybuilder.php" is there.
Yes if I set the kunenalatest module active with kunena settings without CB integration then it's ok! (but of course, no avatar, etc)
(If I try to put either profile or avatar integration, then I get the error message)
I will do some tests tomorrow, hopefully it's only problem of Program Files. I am using xampp for myself and it works from c:\xampp...Thanks for your message, this is my configuration and actions:
OS: Windows XP Pro
Joomla: 1.5.11
PHP: 5.2.8
Kunena: 1.5.3
I will resolve this issue today in version 1.0.41.den07y wrote:
I will do some tests tomorrow, hopefully it's only problem of Program Files. I am using xampp for myself and it works from c:xampp...Thanks for your message, this is my configuration and actions:
OS: Windows XP Pro
Joomla: 1.5.11
PHP: 5.2.8
Kunena: 1.5.3
Great!!!
:woohoo:
Thanks a lot!
I will test it tonight at home (I'm in France).
Cheers,
Denis
