Kunena 6.3.4 released
The Kunena team has announce the arrival of Kunena 6.3.4 [K 6.3.4] in stable which is now available for download as a native Joomla extension for J! 4.4.x/5.0.x/5.1.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 and issues discovered during the last development stages of K 6.3
Note: Please go to the Kunena Dashboard after an upgrade so that the Kunena database tables are also updated.
Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
15 years 5 months ago #131 by mikecsvu
jerry wrote:
Dear Mike,
PM me it. I will keep your site in secret.
Best regards,
Jerry
Hi Jerry
PM sent
15 years 5 months ago - 15 years 5 months ago #132 by Freestyl24
Is there a way to make the module not show the same thread more than once?
Silly me...I figured it out. It's right there in the config.
Last edit: 15 years 5 months ago by Freestyl24. Reason: found solution
15 years 5 months ago - 15 years 5 months ago #133 by jerry
Replied by jerry on topic Re:Kunena latest posts module
version 1.0.35
- You don't need to uninstall. Install over previous version, it just works! Configuration preserverd! :)
- %O gives you online status
- read more gets template style
- serbian translation, thanx kmilos
- new style - "table tr" multicolumn (for holgenoni, set item format to
<td>%C<br />Antw.</td><td>%R %S<br /><small>%N %D</small></td><td>%A</td>
) This format defines table with rows; in item format you must specify table data tags.
Last edit: 15 years 5 months ago by jerry.
15 years 5 months ago #134 by jerry
rincenwin wrote:
I want a suggestion over style. It's possible a style similar than the real forum? Thanks.
Be specific, how it should look like? In most situation this module is used outsite Kunena Forum component, where this module must match template style, not the Kunena Forum style.
15 years 5 months ago #135 by jerry
holgenoni wrote:
is it possible to make KunenaLatest module look like this:
Where to change some fontsize and the alignment of the avatar?
thx
holgenoni
Yes look at annoucement 1.0.35 version, it should work for you
15 years 5 months ago #136 by jerry
klausre wrote:
Hi, is it possible to ad a feature for crop avatar, so it has the same hight and widht?
So do you want to not respect aspect ratio of avatars? I think this is not nice. You can set the avatar height. If you find it usefull to not respect aspect ratio, call for this feature once more.
15 years 5 months ago #137 by jerry
propedeutique wrote:
First thanks for your module which works perfectly.
I have only one issue, related to css styling.
I would like to insert the "readon" class (standard class in joomla template.css) in the module but I don't know how to add this class in your code!
"readon" class should be used to display "Read more" text.
Thanks for your help.
Bye
Thanks for your suggestion. You will find it in version 1.0.35.
15 years 5 months ago #138 by jerry
Well for styling issues with other modules/components. Send me as much information as you have. I will try, to resolve issues on your site.
I think, that's all for now.
15 years 5 months ago #139 by propedeutique
For your information, I am using the mod_kunenalatest (I forgot to mention it! sorry) to display the latest posts.
There is no css class associated with the "Read more" link in this module and I would like to have the css class "readon" associated to it.
Thanks.
Bye
15 years 5 months ago #140 by grumblemarc
Which module are you using? There are 2.
Time to create page: 0.542 seconds
