Kunena 6.2.6 released
Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
So the only thing that i can do is to wait, maybe someone make a template like this some day!
jerry wrote:
You can create new template based on 4 templates in this module. If you submit your changes, we can add this as new template. Templates are files in folder tmpl.[/quote]
It wasn't so difficult like I thought on the beginning.
But I'm not quite sure if the way i made it, is correct.
Because I had to make changes on the helper.php
The template look like this:
And here are the files that I've changed:
The only thing I don't know is how to change the font size of the answers.
Can someone tell me how to do that?
For use just replace the existing files with the attached one. And then go to the module configuration in joomla, and change the layout to "newstyle"!
@jerry
How to implement this in your original?
Thanks so much!
Testing Signature...
Where exactly would I replace these files and where do I change the new layout, in the module itself?
Thanks!
How do we get it to NOT show the username, date etc. But JUST the title of the post?
Thanks so much!
Go to the modules screen, select the latest module, under module parameters on the right side edit the line that says item format. Hover over the title for a little help snippet.
Strange...
thanks for the great module you provided but i need help.
i use RT terran tribune dark template.
i have the Jmod_login in the right but whenever i use the KMod_Latest module it kills the font color of my mod_login module. i have attached a image so you can better understand what i mean. when i disable the mod_latest module it is ok.
its the username, remember me and pw it turns to dark.
any help please,
thanks
VR
