Kunena 7.0.8 Released
Question tags / keywords hack for kunena
17 years 2 months ago - 17 years 2 months ago #19484 by guerilla
i made a tags and keywords hack for kunena.
installation:
first open your database and create a field named "tags" at the jos_fb_messages table has this properties:
name: tags (all charachters must be lowecase)
type: tinytext
null: null
after that copy files to your defaul_ex (or which skin you use) folder.
additionally, if you dont wanna overwrite your old files you can open hack files and search for:
//tags hack by golge
then copy codes between theese statements to your own files.
and finally do not forget to open your language file and add this code under // 1.0.10:
DEFINE('_GEN_TAGS', 'Tags');
change 'Tags' part to your own language...
File Attachment:
File Name: tags_hack_...olge.zip
File Size:32.89 KB
Last edit: 17 years 2 months ago by guerilla.
17 years 2 months ago #19721 by ivovi
Can you show us a screenshot?
I think this plug-in will be useful
17 years 2 months ago - 17 years 2 months ago #19838 by guerilla
17 years 2 weeks ago #27055 by gonzaunit
is a great hacks. good job, i have a one question,You can create a similar post module like vbulletin?
saludos :laugh:
17 years 2 weeks ago #27107 by guerilla
saludos :laugh:
i dont know this module, can you give an example image or link?
17 years 2 weeks ago - 17 years 2 weeks ago #27108 by gonzaunit
the module does not exist, but you could create a plugin it to be like vbulletin for Kunena, this is thanks to the tang. ;)
in vbulletin is thus:
mysave.in/v1/images/0e7h5r0gmqz51se44ha.png
Last edit: 17 years 2 weeks ago by gonzaunit.
Time to create page: 0.262 seconds
