Kunena 6.2.6 released
Idea Modules and Plugins to be upgraded to 1.6.2
1. when user is not logged in and article does not have any comments and the latest module is enabled I get mysql error 1054 (500 - JDatabaseMySQL::query: 1054 - Unknown column 'na' in 'where clause) and the query that causes it is:
2. discussbot plugin installs languages in the administrator folder instead of the language folder.
3. when topic deleted, its jos_kunenadiscuss entry is not deleted.
JDatabaseMySQL::query: 1054 - Unknown column 'na' in 'where clause' SQL=Select COUNT(DISTINCT t.thread) FROM jos_kunena_messages AS t INNER JOIN jos_kunena_messages AS m ON m.id=t.thread WHERE m.moved='0' AND m.hold IN (0,1,2,3) AND m.catid IN (na) AND t.hold IN (0,1,2,3) AND t.moved=0 AND t.catid IN (na) AND t.time>'1286585596'
Call stack
# Function Location
1 JSite->render() C:\wamp\www\ispania_kunena\index.php:79
2 JDocumentHTML->render() C:\wamp\www\ispania_kunena\includes\application.php:168
3 JDocumentHTML->_parseTemplate() C:\wamp\www\ispania_kunena\libraries\joomla\document\html\html.php:249
4 JDocumentHTML->getBuffer() C:\wamp\www\ispania_kunena\libraries\joomla\document\html\html.php:386
5 JDocumentRendererModules->render() C:\wamp\www\ispania_kunena\libraries\joomla\document\html\html.php:190
6 JDocumentRendererModule->render() C:\wamp\www\ispania_kunena\libraries\joomla\document\html\renderer\modules.php:41
7 JModuleHelper->renderModule() C:\wamp\www\ispania_kunena\libraries\joomla\document\html\renderer\module.php:84
8 require() C:\wamp\www\ispania_kunena\libraries\joomla\application\module\helper.php:173
9 modKunenaLatest->__construct() C:\wamp\www\ispania_kunena\modules\mod_kunenalatest\mod_kunenalatest.php:31
10 modKunenaLatestHelper->getKunenaLatestList() C:\wamp\www\ispania_kunena\modules\mod_kunenalatest\class.php:42
11 CKunenaLatestX->getLatest() C:\wamp\www\ispania_kunena\modules\mod_kunenalatest\class.php:100
12 JDatabaseMySQL->loadResult() C:\wamp\www\ispania_kunena\components\com_kunena\funcs\latestx.php:480
13 JDatabaseMySQL->query() C:\wamp\www\ispania_kunena\libraries\joomla\database\database\mysql.php:355
14 JError->raiseError() C:\wamp\www\ispania_kunena\libraries\joomla\database\database\mysql.php:231
15 JError->raise() C:\wamp\www\ispania_kunena\libraries\joomla\error\error.php:171
16 JException->__construct() C:\wamp\www\ispania_kunena\libraries\joomla\error\error.php:136
vatoloco wrote: fxstein I have sent you a PM with my backup!
This was a nasty one to find.
Just got done with the root cause analysis. Have been on this on and off for the past 3 weeks. It turns out to be a plugin event recursion that hits in certain configurations.
In your case the combination of Kunena + JomFish + JomSocial leads to a 'deadly' event recursion where the plugin creates a new thread on the first reply, which triggers an add to the JomSocial activity stream, which renders the topics, which contains an article, which fires a content event on rendering and back to the beginning.
It will circle in that recursion until php crashes. On a decent server that is a couple hundred posts. My MacBook does about 1000 new threads in that bug.
FYI found the best way to delete them is to temporarily increase the numbers of topics per page to 1000, click the select all marker about the first line, unselect the few that don't belong there, and then delete them all at once. Do the same a second time for permanent deletion and they are gone for good.
There is a simple workaround with the lastest discuss plugin builds: change the format of the initial topic to 'link' - it will embed just a link and not the fully rendered article - therefore no recursion. You can change the topic starter after that manually to include the article bbcode - no issue.
The fix requires a fix in Kunena 1.6 itself - we might accelerate Kunena 1.6.2 for that and a check inside the discuss plugin.
Writing the fixes now. Use the workaround until we have the fixes out. Hope to have test builds within a day or two.
Thanx in advance for all the work you are doing on Kunena.
Looks like it's delayed again...
