- Thank you received: 566
Solved [Merged topic] Kunena Latest doesn't display posts to visitors
There are 4 fields for user groups; primary & secondary group/children. Both are effective, so if you have wrong group in secondary field, all users can see the topics.
- claudiodestasio
I have a similar issue. With cache activated the module kunena latest don't show latest post to visitors but only to registered members. Visitors see an old cached version never refreshed. I have to manually clear the cache!
I don't know PHP programming but i have solved the issue modyfing mod_kunenalatest.php removing the "basic caching" fo visitors in this way:
// Add basic caching for visitors (3 minutes)
$klatest = new modKunenaLatest ( $params );
// $user = JFactory::getUser();
// if (!$user->id) {
// $cache = JFactory::getCache('mod_kunenalatest', 'output');
// $cache->setLifeTime(180);
// if ($cache->start(md5(serialize($params)), 'mod_kunenalatest')) return;
$klatest->display();
// $cache->end();
The forum is:
www.studiodestasio.it/forum
Ideas?
My Latest Posts module will only show the latest posts if the user logs in even though I have guest post access enabled. How can I get the mod to show the latest posts to everyone whether they log in or not?
- Jiminimonka
- Elite Member
- YBAS!
Using the search feature will help, also posting in the right place.
G'day, ccvortex, and welcome to Kunena.
Thank you for your question (although I'm fairly sure that we've been asked about these things before). As Jiminimonka has written, sometimes it's easier to spend a few moments searching the forum for the answer.
I'm guessing that you are using K 1.7.2 with Kunena Latest 1.7.1. Is that right? It would help if I did not have to guess the other information that might help us, if you posted your configuration report. See the FAQs menu item above the forum page and read What information should I include when I ask for help (including how to post my configuration report)?
Thanks.
Correct, I am using forum version 1.7.2 and module version 1.7.1. This is on Joomla 1.5.23 using the standard Joomla rhuk_milkyway template. Both the PHP and MySQL versions are the latest.
Is there any way to get the module to show the posts to everyone regardless of login status?
Thx again
