Kunena 5.2 RC3 Released (29 Nov 2020)
The Kunena team is thrilled to announce the third public release candidate of Kunena 5.2, a native Joomla extension for Joomla 3.9. This is a development release and should be only be used for testing; this version is not recommended for live websites at this stage.
The purpose of this release is to encourage testing by downloading, installing and identifying any problems or shortcomings that people may discover. K 5.2.0 RC3 is stable and we are aware that people will discover defects. We encourage you to use the forum to report defects, as soon as they are discovered, so that the development team can work through the problems before the release of K 5.1 as a stable product. Reporting defects does not mean that the problems can or will be fixed. The Kunena team is looking forward to hearing your feedback on how well we have achieved our design goals.
Question [gelöst] Threadüberschrift erlebt optische entgleisung
11 years 8 months ago #11 by blacksh33p
hm tut nix is doch gleiche wie ebend. sagt jedebfalls compare
11 years 8 months ago - 11 years 8 months ago #12 by Lintzy
Ich dreh gleich durch, egal wie, der code wird immer verkehrt angezeigt. Du musst den slash / am Anfang und die '' am Anfang und Ende entfernen von:
(images/pathway_start.gif)
(images/arrow.png)
(images/pathway_finallink.gif)
Last edit: 11 years 8 months ago by Lintzy.
11 years 8 months ago #13 by Lintzy
Jetzt wird es richtig dargestellt, weil es nicht innerhalb der codetags steht. Man, man ich dreh gleich durch :woohoo: ;)
11 years 8 months ago #14 by blacksh33p
jop super nun gehts.
super vielen dank
11 years 8 months ago - 11 years 8 months ago #15 by Lintzy
.egalwas {
url(images/pic.gif);
.egalwas {
.egalwas {
(images/pic.gif)
11 years 8 months ago #16 by blacksh33p
habe noch eine frage, aber bin mir nich sicher, obs am ger template liegt.
hab eingestellt, dass er bei avatar und cb das community builder profil nimmt.
leider zeigt er nun keine signaturen mehr an. hast da evtl eine idee oder ein tipp wo ich anfangen kann das problem zu suchen?
11 years 8 months ago #17 by Lintzy
Haha, dein Post ist in den Geistermodus versetzt worden, du musst den abgeschickt haben, als ich den thread gerade in das andere Forum voerschoben hab.
Da ich das Thema noch abonniert hatte, konnte ich deinen Text in der Mail lesen:
Nachstehend eine Lösung dafür, es soll demnächst auch ein neues Plugin für CB erscheinen, das dieses Problem löst.
www.kunena.com/forum?func=view&catid=12&...mit=10&start=10#8419
11 years 8 months ago #18 by blacksh33p
hehe ok super dank dir :)
  • Not Allowed: to reply.
Time to create page: 0.097 seconds
